Rotate ICE by hand - no tools, hypothetically
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pasadena_commut, May 9, 2026.
  1. ChapmanF
    18,975
    It occurs to me that I could have been less snarky in #18, and said something more like this:
    Most of the time, when I've seen posts insisting on something "because laws of physics" that turn out not to hold up, it certainly isn't because the laws of physics were wrong, and usually isn't even because the poster misapplied the laws of physics.
    It most often ends up being somewhere in the simplifying assumptions and approximations somebody made about the question—and regarded as so obvious as not to need any empirical testing—before applying the laws of physics to them.
  2. PrimalPrius
    PrimalPrius Member
    138
    America
    No worries. I was just saying that the engine can't "fire up and break the slacking chain" because first it has to rotate enough to compress an ignitable mixture in at least 1 cylinder, etc, etc. With all that said, I still turned mine clockwise last (the tensioner is always on the "slack side").
    (The potential concern could be jumping timing. There should not be enough slack possible to jump a tooth with a chain. Maybe it could be a concern with a timing belt? I would think that any engine with a timing belt that is offered with a manual transmission would need to be designed to tolerate a situation in which the car is allowed to roll back in gear with a stopped/stalled engine and then started.)
    #22 PrimalPrius, May 16, 2026
