Rotating Tires/ can't get rear tires off
Discussion in 'Gen 2 Prius Main Forum' started by filiberti, Aug 30, 2006.
  1. chimo
    chimo Junior Member
    81
    Ottawa, Canada
    Re: Rotating Tires/ can't get rear tires off
    +1 on this method. I have had to do this many times with other vehicles. Saves time as well.
    Silver Pine Mica likes this.
  2. Patrick Wong
    18,212
    6,529
    As suggested in the above posts, you should try loosening the lug nuts and then moving the car up & down on your driveway. Hopefully that will loosen the rear wheels.
    I hope you are using four winter tires.
  3. patsparks
    10,664
    569
    Adelaide South Australia
    I just hit the outside of the tyre with a big hammer, not the rim, the tyre. Make sure you add never-seize to the spigot hole in the wheel.
  4. rfelley
    rfelley Junior Member
    42
    Oregon
    I'm assuming you got the nuts off but the wheel is stuck. If you don't have a size 12 foot, then get a friend with that size, ask them to put on a steel-toed boot and give it a good kick. It will come off.
    Then, before reassembling, apply a little grease to the hub area that was stuck.
    Rich
  5. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Sorry replied too soon. How do I delete this post?
  6. patsparks
    10,664
    569
    You can't, don't worry about it though.
    Oh, when trying to get a wheel to come loose, make sure the nuts are on the studs loosely to prevent the wheel flying off and doing harm.
  7. 2009Prius
    2,705
    512
    63
    There are essentially two methods suggested above: 1. kicking/hammering and 2. driving back and forth. My question is which one is more gentle (to avoid damaging the hub or the wheel)? Thanks!
  8. Silver Pine Mica
    Silver Pine Mica Junior Member
    48
    22
    Columbia, Missouri
    This method worked for me.
