Rough idle at stoplight - dash says motor off
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by VicVinegar, Apr 8, 2014.
  1. VicVinegar
    VicVinegar Member
    275
    53
    Northern Virginia
    I tried searching and only found rough idle at startup, so here is my issue. At the same point in my AM drive, quite often I'll come to a stoplight and the motor will idle fairly roughly. If I switch to the "car" on the dash, it indicates the motor should be off. It is not charging the battery. Today it did it when I was only one bar from full battery. Also did it at the next light I came to.
    This happens at the end of the commute. I've already covered 40+ mostly highway miles.
    No rough idle issues other than this to speak of. It it "normal" or an issue for my 20k service? Car has almost 18k on it now.
  2. ccdisce
    ccdisce Active Member
    259
    187
    Stone Mtn GA USA
    IMHO I think that your car could be 'Dieseling' which could be due to a higher than 'normal' compression or a hot spot cylinder deposit.
    As a first check you may want to check the oil level to see if it is within the limits and you may not want to wait until 20k service, an oil pressure within spec may be needed to set the Variable Valve Timing ( which could influence the compression ratio )
    From personal experience in my previous cars, dieseling and detonation tends to be a problem in the early spring and a side benefit is that at that time of the year for about 2-3 weeks I get the highest MPG readings.
  3. Roland1555
    Roland1555 Senior Member
    282
    69
    Vancouver BC
    Not a normal issue. Make an appointment and get it examined. You are doubtless still covered under warranty.
    Try to arrange things so that it might be reproducible... have them prepared to have a tech on hand for a drive with you in the car. Nothing more annoying than hearing that it didn't do that when we drove it.
    Roland
    frodoz737 likes this.
  4. Andrii
    Andrii Junior Member
    Miami, Florida
    Not really sure how right i am here, just a little tip. I heard there is a recall on some priuses, concerning the software update for the engine. Maybe this free update could fix an issue. Good luck
    P.S.:
    To check your recall eligibility, go to Toyota Safety Recall and Car Service Information and enter your VIN
  5. bisco
    52,855
    are you running regular gas? 87 octane.
  6. VicVinegar
    VicVinegar Member
    275
    53
    Northern Virginia
    Thanks for the suggestions. I've had the recall performed, using regular 87 gas from a high volume station. I'll double check the oil, but I thought I checked it after the last change and everything was squared away. I'm fairly certain it did this when it was cold too, although it was about 45 this morning. Fuel economy is a little disappointing recently now that I'm not chalking it up to cold weather and has me reading the recall thread where others have noted the same.
    I believe it has happened a handful of times other than on my AM commute. Can't recall the scenario, and I'm pretty sure it did it a few times before the recall. After noticing it a few times in recent weeks at this first stoplight after doing 40-45 miles in the AM, and again this morning, I figured I would search on here and post. This morning it idled roughly for a good minute or so until the light turned, and then did it again for about 20 seconds at the next light before shutting down.
  7. bisco
    52,855
    something is definitely wrong. how bad are your mpg's?
    did the ice misfire before the recall?
  8. VicVinegar
    VicVinegar Member
    275
    53
    Northern Virginia
    Not too bad. Warm weather last year I was usually around 47-8. I'm at about 45 on this tank and need to check the air pressure. Nothing too dramatic, but lower and I was curious if that is what other recall folks have seen.
    I've also noticed the car seems to eat into the battery more during "normal" driving. I don't recall ever noticing the battery losing more than a couple blips on highway driving, but I've noticed it at half since the recall. Really the only time it used to use battery capacity was in traffic.
    It did, but I'd say the occurrences were spread apart enough that I just brushed it off as a one off. Recently though I guess I've noticed it more, and at the same spot, leading to today. I thought about bringing it up at 15k, but figured it would be tough to replicate.
  9. VicVinegar
    VicVinegar Member
    275
    53
    Northern Virginia
    Wanted to bump this as I get close to 36k. I've continued to have this happen, although not always a rough idle. The ICE will keep running at a stop for what appears to be no good reason once I get done with the highway portion of my commute. Cabin is warm, so it shouldn't be trying to create heat. Battery is full and the gauge doesn't indicate it is charging anything. I took a video about a week ago just to show the motor running and the gauges. Probably take one more next time it happens.
    I don't notice it happening nearly at all when it is warm out. It is most frequent in the cold.
    Anyone else experience this? Last time I brought it up at a service they did the old "Well if we can't experience it, we can't do anything". There has to be something they can check.
  10. bisco
    52,855
    yes, you never know when or why the ice runs, unless you understand all 5 stages of warm up. mpg is a better indicator of overall health. with my '08, i would rive my commute, which is 4 miles of back roads then 2 miles of highway. even on a 80 degree day, after i got off the highway and approached my office a mile away, going 10 mph through an industrial park, my engine would run the whole time.
    #10 bisco, Jan 25, 2015
  11. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    The key to me is the "rough idle".
    I let the HSD decide when the engine should run, and when it shouldn't and unless my MPG plummet, I assume it's making the right decision.
    But running or NOT running the engine should not really idle rough. Especially if this is at the end of a commute and the vehicle is warmed up.
    Assuming you bought this car new, and it now has 18K, and this behavior has recently manifested? I'd just go have it checked out. The OP is still under warranty.
    It's tough if the circumstances are so specific that the dealership is saying they can't duplicate.
    How often does this happen? Is it intermittent enough that one could simply consider these rough idling incidents simply "Winter" or "Winter Fuel"?
    Or is it happen so often that it IS a real problem?
    Even though I think it's benefit is very questionable. I do run a bottle of Techron through my fuel system about once every 10,000 miles.
    You could try running a bottle and seeing if that helps at all.
    #11 The Electric Me, Jan 25, 2015
  12. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    In my experience going back to 2006 with the Gen II, the ICE continues to run after coming to a stop for a couple of reasons: 1) the traction battery is full, and the electronics are spinning the motor to deplete battery charge, 2) it's cold outside and you are using the climate control to warm the cabin. Under condition 1, you are not using any gas to run the ICE. In condition 2, you are using gas so that the ICE will produce heat to warm the cabin.
  13. Former Member 68813
    3,524
    983
    US
    for the record, dieseling (after ignition is turned off) is only applicable to carburated engines. The only reason I know it, I have a boat that is hard to stop when hot.
    I had one or two instances when engine started and stopped for no good reason when sitting (warm engine, no heating, almost full battery, etc). Some kind of software glitch I think. If I were the OP, I would disconnect the battery to clear volatile memory.
  14. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    I don't think the Prius can diesel. The ICE does not just idle freely, it is coupled to MG1 and MG2. If the ICE is running when it is not expected, you'd bet MG1 and MG2 would complain and throw a code.
    As stated above, I think it is hardly plausible for a fuel injected car to diesel. Running an engine requires two things: 1)Ignition source, and 2) Fuel. Once a fuel injected engine is turned off, the injectors are shut off, how does it diesel?
    I have read reports of the ICE running excessively with no code, due to battery over temp. Have you checked your battery cooling vent for blockage?
  15. VicVinegar
    VicVinegar Member
    275
    53
    Northern Virginia
    I guess this could make the most sense, that it is trying to burn off charge. Other than that, the cabin is plenty warm by the time I get home. I've been in the car for at least 50 minutes by then.
    It still does not run roughly all the time. It did today actually. I pulled into my garage after the hour-plus long, 41 mile commute home on mostly highway, with the final stretch going 75 mph or so, and after stopping in the garage it roughly idled before it shut off, then I turned the car off. I wasn't quick enough to get a video going.
    Vents are not blocked. I'm pretty much the only person ever in the car, so there is nothing in my back seat.
    I'm at 34k now, so if there is a problem I want to try and get it taken care of asap.
  16. bisco
    52,855
    have you had it checked for codes?
  17. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Wouldn't any code light up the dash like a Christmas tree?
  18. VicVinegar
    VicVinegar Member
    275
    53
    Northern Virginia
    I haven't plugged my OBDII in for a while, but there has never been a Check Engine Light.
  19. bisco
    52,855
    they don't come on with every code.
  20. kc410
    kc410 Active Member
    263
    255
    2010 Prius IV
    I've had something similar to this happen when my traction battery was going south. As the traction battery got worse, I could duplicate this trouble anytime. Since (recently) replacing the traction battery I have never had this reoccur.
    I actually documented this within minutes of it happening:
    Its a warm (80°) at 10AM August morning. All of this is with the AC running.
    Starting with a "cold" engine I drove ~2 miles to the Interstate, then drive ~12 miles at 70+ mph.
    At my exit I slow down with the brake just enough to watch the regen. bar go fully to the left & slow all the way down 70-to-0 & end up stopped at a traffic light. The battery gauge went up to 1-bar-from-top & the engine shut off (as usual). After 2-3 seconds at the light the engine starts up & idles. I don't remember it idling rough but it may have & I never noted it. The engine idles ~15-20 seconds then shuts off. While at the light I got out my phone & fired up Torque. The BT adapter is always connected & when Torque connected I could see a 0.7V difference between the highest & lowest of the 14 battery module pairs. The rest of my drive was eventful.
    In "normal" driving the Prius attempts to keep the battery at 60% State-Of-Charge. Using regeneration braking from 70 to full stop would push the SOC to ~65-67%. One of the on-board computers did not like the high battery voltage & decided to start the engine to perform some test. It fires up the ICE & everything looks OK so it shuts down the ICE & continues.
    Eventually it starts setting a "pending code" P0A80. The only way to see the code (or that a trouble might exist) is to use a OBDII code reader.
    Looking at the dash lights, there would be no indication of a problem.
    At the time I already knew the traction battery had a problem. I had been monitoring the 14 batt. voltages & noted one that was not trending the same as the other 13. Torque worked very well for me, to monitor these voltages.
    Former Member 68813 likes this.
