Rough idle at stoplight - dash says motor off
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by VicVinegar, Apr 8, 2014.
  1. VicVinegar
    VicVinegar Member
    275
    53
    Northern Virginia
    Effing dealership wants to charge me $110 to look at it, even though the car is under warranty. Basically it is apparently my job to figure out if there is a problem for warranty repair. Is this normal? I just had my Subaru in and they checked out a noise I had no charge... because it was under warranty.
  2. kc410
    kc410 Active Member
    263
    255
    2010 Prius IV
    Until the Prius sets a hard trouble code, the service dept. has no idea what to repair.
    Even a "pending code" set in the ECU will not light up anything on the dash, not that a dealer would do much about a "pending code" anyway, except maybe reset it.
    I knew my battery was failing from monitoring it (using Torque) for a long time. I could tell something was failing from the way the Prius was acting, but it only started setting a hard trouble code at the very end of its life. I'm not saying your trouble is with the traction battery but until the service department gets to see a hard trouble code they (mostly) are lost.
    It might be worthwhile to pay the dealer the $110 just to try & document if there is a failure while it is still under warranty. A BT adapter ($20) & Torque Pro ($5) & you can look at lots of things yourself.
  3. VicVinegar
    VicVinegar Member
    275
    53
    Northern Virginia
    I have an adapter and Torque. Came in handy with a Civic that was north of 200k. So I guess I'll work on my 1.5 year old, 35k mile car myself. I was just hoping they would have an angle to inspect based on the description of the problem. They are supposedly the experts on these things. I know the tech lines sometimes know of issues that aren't issued in TSBs.
    I just have a problem paying $110 so they can tell me there were no codes, which is what I feel the result would be. Or else I am gambling that they have a tech who really cares about getting to the bottom of things. Probably not.
    Pretty sure I am done with this service department though. The dealer I bought from and was using is pretty inconvenient for me, so I tried this one that is 5 minutes from me. After my 2.5 hour 30k service, I'm apparently looking at a 90 minute tire rotation for 35k. No shuttle on the weekend too, because that makes sense.
  4. kc410
    kc410 Active Member
    263
    255
    2010 Prius IV
    If you can get the Prius to the other dealer they might have a better service department? Try to make an appointment? Call your salesman if necessary? Not all Dealers & Service Reps. are created equal. I know its a pita, but you are correct in wanting to find out what is gong on with _your_ Prius - & getting it checked out while still under warranty makes sense :) Good Luck
  5. VicVinegar
    VicVinegar Member
    275
    53
    Northern Virginia
    Yeah I'll probably check with them and go back to them for service in general.
