Routine replacement engine w pump
Discussion in 'Gen 2 Prius Main Forum' started by tjli, Feb 3, 2011.
  1. tjli
    tjli Junior Member
    Wife took in our 2007 Prius for the HV water pump recall and was told we needed to replace the engine water pump as well at 70K. We have about that now on it. Dealer said it was routine and depends somewhat on how vehicle is driven. Sounds like bull*()^ to me.
    Anyone else have this experience or need the engine water pump routinely replaced.
  2. Patrick Wong
    18,200
    6,493
    It's certainly possible that the engine coolant pump needs to be replaced at 70K miles. I suggest that you look for yourself: ask for the car to be raised up on the hydraulic lift, and then ask to be shown where the coolant is leaking. Typically you will see a pinkish or whitish stain coming from the coolant bearing.
    If you don't see a coolant stain then there is no need to replace the engine coolant pump.
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    It may be time to find another dealer to service your Prius.
