rpm at 70 mph
Discussion in 'Gen 3 Prius Technical Discussion' started by sunder, Apr 20, 2013.
  1. sunder
    sunder New Member
    Does anyone know the typical rpm of the 2012 prius at 70 mph? I am trying to keep my rpm around 2500 to minimize wear and tear for long diatance. I ned to find a way to check temp and rpm with after market prosucrs, what works?
    Thanks, sunder
  2. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    If you own a smart phone, the torque app / Bluetooth obd2 reader will get you all the information you ever desired.
    The the stand alone scan gauge II is also an excellent monitoring tool.
  3. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I forget but it's nowhere near 2,500rpm. The Prius runs at a ridiculously low RPM at freeway speeds.
    That being said, the actual RPM is going to be based on load because of the eCVT nature of the power split device. So it's not like an old school fixed gear transmission. 70mph driving can be done at 1,000 to redline depending on the load. Toyota Prius - Power Split Device
    Honestly, don't worry about it. You're not going to hurt the ICE. I'd worry more about the battery and keeping the transaxle fluid clean by changing regularly.
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    2400 is not uncommon I use a scangauge II
  5. fuzzy1
    10,722
    While not uncommon, that is well above average, and indicative of acceleration or hill climbing. At least it is in the Liftback, the 'v' wagon likely has a higher RPM.
    I think in flat steady driving at 60 mph, RPM spends most of its time between 1300 and 1600. Wheel and engine speeds are not directly linked as they are with traditional transmissions, so RPM will rise faster than proportionate to road speed.
  6. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Why does it matter if the engine is designed for it? The computers will not endanger the drive train components.
  7. Former Member 68813
    3,524
    983
    US
    I just came back from a road trip, mostly at 70-71 MPH (~51 MPG indicated) and RPM ranged from 1000-2700 depending on grade. I'm not good on spotting a flat road in hilly terrain, but it looked somewhere between 1700 and 2300. BTW, the speedometer was 1-2 MPH high compared to GPS.
