RPM at 75-80 mph
Discussion in 'Gen 3 Prius Technical Discussion' started by lm2, Jul 15, 2009.
  1. lm2
    lm2 New Member
    Los Angeles
    For those who have the scan gauges or whatever they are called, I'm interested in knowing the engine rpm at about 75 or 80 mph on level terrain. If I get a 2010, I would want to take longer trips. I would be willing to trade some mpg for mph. In one thread, it was mentioned that the owner only saw the redline (5200?) at 75+ mph. A long trip at near the redline would not be fun. Any help would be appreciated. Thanks.
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    The Prius has a continuously variable transmission, so at 75 MPH (119 kmPH) the engine can be spinning as low as 1130 RPM or as much as redline (5000 RPM) in my 09. The 10 will be similar: actual weight of the car, State of Charge (SOC), and warmup mode will all change the actual RPM at any given speed on level roads.
    I use this simulator, A simulation of Prius's Planetary Gear which, as an example, shows you can't get to redline in a 09 until 55 MPH. even when accelerating.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
    [ame=http://video.google.com/videoplay?docid=3834454834833982503]Prius e-CVT in action: A view of gas engine RPM at 65 MPH.[/ame]
    I recorded it in my 2006 Prius at 65 MPH. That should give you some idea. I read in a document that 2010 Prius ICE spins 300 RPM less at 70 or 75 MPH due to more torque from the larger displacement.
  4. ken1784
    ken1784 SuperMID designer
    2,940
    1,359
    67
    Yokohama, JAPAN
    The Japanese sales staff manual says following data at 120km/h(74.6MPH).
    item 2G 3G
    1 engine RPM 2 470rpm 2 180rpm
    2 MPG 40.5MPG 44.7MPG
    Please note that higher speed always worsen your mileage at highway.
    Ken@Japan
  5. dogfriend
    7,512
    1,185
    Carmichael, CA
    I've gone 80 mph @ 960 rpm.
    Downhill. :madgrin:
  6. lm2
    lm2 New Member
    Los Angeles
    I want to thank all of you who gave me the information on "rpm at 75-80." Especially, thanks for the video, Seawolf. It seems that higher speeds don't necessarily mean high rpm's; although I know the mpg would suffer. Thanks again.
  7. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    For my own curiosity, what's the MAX RPM at that speed? When accelerating onto a freeway from a metered light, I've reached about 70-75mph, and it didn't "sound" like the ICE reached it's maximum speed until somewhere in that neighborhood, which either suggests the max RPM is higher than 5200rpm or the extra 200 RPM compared to the max speed of MG1 takes another 10mph to be attainable.
    Now here's my catch with this. If 5200rpm isn't reachable until well into 70mph, will MG2's speed be higher than it's horsepower peak? If so, how can Toyota rate the net power of the Prius HSD system at 134hp if neither sub-system will reach it's theoretical HP peak at the same speed?
  8. bwilson4web
    15,411
    Perhaps this might help:
