Rubber cover for light 2007 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by The Mage, Mar 9, 2023.
  1. The Mage
    The Mage New Member
    Nebraska
    I
    I just replaced the driver-side light in my 2007 Prius, and cannot get the rubber cover back on. I have spent hours trying to get it back on, and am completely confused as to why it won't go back on.
    I attempted to match the bumps with the slots and tried twisting to get it to pop in, moved it in multiple directions, and I have yet to get it in place.
    Is there some sort of trick to get it back on?
  2. JC91006
    16,933
    8,643
    You can remove the headlight assembly and then put it on. Just have to slide the bumper off, 10mm bolts, a few clips and a couple phillips screws.
    SFO likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,411
    5,413
    Pacific Northwest, USA
    Had the same problem first time I replaced headlight bulbs... But don't give up... The right amount of force at the right spots will eventually be figured out. I can change both bulbs in a Gen2 Prius in as fast as 8 minutes now that I've practiced so many times!
  4. The Mage
    The Mage New Member
    Nebraska
    I
    I saw videos on this, and really I don't want to take apart the car just to change a light. But I already changed the light, the only issue is getting the rubber part back on. (Driver side.) I have the location, and I seem to know the position, it just won't go in.
  5. PriusCamper
    13,411
    5,413
    Maybe some soapy water? Or just wrap it in gaffer's tape or duct tape and deal with it next time there's a reason to remove the front bumper cover?
