Rubber plugs installed at pre-delivery inspection?
Discussion in 'Prime Main Forum (2017-2022)' started by drager21, Jul 14, 2017.
  1. stuyguy
    stuyguy Active Member
    170
    134
    Lakewood, CO
    2024 Prius Prime
    XSE
    I found these in the glove compartment when I picked up my Prime. Sales guy said he didn't know what they were and tried to pocket them when I asked. I googled the part number (90950-01259 INAOC), and he sheepishly went and installed a spare pair himself
    Stevarino and Mendel Leisk like this.
  2. Mendel Leisk
    42,369
    With our 2010 I found the plug installed one one side, missing on the other, that got me making phone calls. Makes you wonder what you're paying pre-delivery inspection fee for: what else have they neglected.
  3. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    They missed installing them because they were busy putting on the dealer logo!
    So do you treat the "slackers" like in "Back to the Future I" (detention), or "Back to the Future II" (shotgun)? ;)
    #23 David Beale, Mar 12, 2018
  4. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Slackers should get introduced to business end of cricket bat.
  5. William Redoubt
    William Redoubt Senior Member
    1,228
    1,174
    Coronado Island, California
    StanceNation has infected even the super sane ranks of hybrid owners.
  6. Dael
    Dael Member
    137
    32
    Ohio
    2020 Prius Prime
    So they have to replace a transaxle seal during the PDI? That is intrusive. How many actually do it? How many leak after the fact?
  7. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    If you are asking about the plastic plug, it is not for the transaxle seal. It's a plug for the underside body frame part. I never checked mine but did not have the plugs in my glovebox. So, I assume they are in.
    As for the “Health Check” during PDS, I never received any paperwork on them. I don't know if they did check the transaxle level as suggested in the service bulletin. To be honest, I don't think they even check the level during routine maintenance when it is called for. No, I have not heard any report here in PC about any "leak".
    Dael likes this.
  8. Dael
    Dael Member
    137
    32
    Ohio
    2020 Prius Prime
    Right, yes not assuming plugs are transaxle related. So is there no dip stick for tranny? or is this a separate component gear box attached to front wheel drive tranny?
  9. Dael
    Dael Member
    137
    32
    Ohio
    2020 Prius Prime
    more than you want/need to know :D
    4th Gen Prius, Prius Prime Transaxle - P610 Quick Look
  10. Mendel Leisk
    42,369
    I think that's the washer on the transaxle fill bolt. No problem there.
    Kinda overkill though, checking the transaxle fluid level, think I'd prefer they leave it alone. If it was fine at the factory, it would continue to be fine on the other side of the Pacific. :rolleyes:
    I'd suspect a lot of dealerships skip this one.
    Dael and Salamander_King like this.
  11. Salamander_King
    11,024
    8,980
    New England
    Correct. No dipstick for a transmission-level check on any PRIUS including PRIME, AFAIK. And there is no separate gear box. In fact, as I understand it, there is no "transmission" or "gear box" in PRIUS to be exact. The only way to check the level of the fluid is to open the "fill" plug and stick your finger into the hole.
  12. Trollbait
    12,832
    What new car has a dipstick for the transmission? The newest car I owned with one was a 2004 Matrix.
    You're assuming it was fine from the factory:sneaky: Even that was the case, I wouldn't trust the dealer to check it.On the HHR, if the engine wasn't running when the check/fill plug for the transmission was opened, a third or more of the fluid would pour out.
    It's a transmission. We call it a transaxle to make ourselves feel special. There is a planetary gear set buried in there, which other transmissions make use of.
  13. CharlesH
    2,798
    1,166
    Roseville, CA
    I guess that whether what the Prius has is a transmission depends of your definition of "transmission". Yes, it transmits power. Does that make it a transmission? Conventional transmissions have gears that engage and disengage, along with belts and clutches, to "shift gears". Of these, the only thing the Prime has is a one-way clutch in the planetary gear set that allows MotorGenerator 1 to power the wheels without turning the gasoline engine backwards. Nothing "shifts" in the Prius transaxle. While a conventional transmission has 800 parts that need service (per an AAMCO TV commercial :)), the Prius transaxle has more like a dozen parts (and a bit of software).
    Dael likes this.
  14. Trollbait
    12,832
    It's a little more that a bit of software, which was a source of stalling and a recall.;) M/G1 is also an important part of the HSD transmission. It is its varying input that changes the effective gear ratios of the transmission. Which makes the transaxle more than a bike chain and equal in to a conventional transmission in a car's drive train.
  15. Dael
    Dael Member
    137
    32
    Ohio
    2020 Prius Prime
  16. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    Definitely a transmission. A CVT continuously variable transmission. A gearbox that connects the prime movers (motors & engine) to the axles.
  17. Gokhan
    Gokhan Senior Member
    6,715
    2,672
    Paramount CA
    Prius CVT is very similar to a conventional automatic transmission in that the heart of the transmission is a planetary gear system. In a conventional automatic transmission, different gear ratios are obtained by applying the brake bands through the wet clutches in the transmission to different parts of the planetary gear system (such as the sun, planet, or ring gears) to stop them from turning, which effectively changes the gear ratio. In the Prius CVT, instead of doing this (braking one of the gears to a complete stop), the turn speed of one of the gears (I think it was the sun gear) is continuously varied by the motor - generator that is attached to it, which effectively changes the gear ratio of the planetary gear system in a continuous manner. There are no belts, chains, and/or conical pulleys involved as in older CVTs.
    #37 Gokhan, Sep 9, 2019
  18. Gokhan
    6,715
    2,672
    Paramount CA
    These are pictures from my 2020 Prius Prime XLE, left and right sides, respectively, the rubber looking fresh and shiny.
    srivenkat, Stevarino and Mendel Leisk like this.
  19. CharlesH
    2,798
    1,166
    Roseville, CA
    I couldn't find the "sarcasm emoticon" when I said "a bit of software". As you say, the software is far from trivial. Lots of real-time, sophisticated software that has crazy-severe reliability requirements.
    jb in NE likes this.
  20. Mendel Leisk
    42,369
    Good spot for jack stands at the back. Turn the cradle to be longitudinal.
    Gokhan likes this.
