Rubber Plugs not installed by dealer on delivery
Discussion in 'Gen 2 Prius Main Forum' started by mootsman, Jul 25, 2006.
  1. mootsman
    mootsman New Member
    109
    Howdy,
    I found these in the glove box of my new Prius. They are rubber plugs that have instructions printed on them indicating that they are to be installed as part of the pre-delivery function. They go into the end of some frame members. So.....ignore it or crawl under the vehicle and attempt to install them?? I'm mechanically oriented but had just as soon not fool with it if not necessary. Thanks for any info.
    [attachmentid=4247]
  2. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    Don't ignore it. If you're not inclined to put these in yourself, by all means take it back to the dealer.
  3. tyrael
    tyrael Junior Member
    59
    San Diego
    You know what? They didn't put mine in either! I'm going to go back for sure.
  4. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    When I went back to my dealer, I asked them what these things were for. The reply was, "Oh, this is embarrassing. They shouldn't be there. We have a whole bucket of these things and just install on of those because it's easier. You can throw them away."
    I'd check, but either they've already installed them or they need to install them.
  5. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    i found them in my glovebox too. i just reached under the car and popped them into place. a couple of minutes tops. put em in if you like, i think they help with corrosion prevention or something like that.
  6. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    This is exactly why, upon delivery (at the dealer) you follow the Prius Delivery Checklist. The plugs are on the checklist. The dealer should supply the checklist. You should follow the checklist and go over the vehicle together before you leave for home.
  7. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    So where do these plugs belong? I didn't have any in my glove box, and I'd like to verify that they're installed.
  8. Lil Mo
    Lil Mo New Member
    171
    <div class='quotetop'>QUOTE(Rick Auricchio @ Jul 25 2006, 06:55 PM) [snapback]292337[/snapback]</div>
    Walk out to your car, drop your trousers, bend over, and...
    (Okay, I apologize, that was too hard to resist. If galaxee put them in, there is a chance that normal humans can figure it out. :p )
  9. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    There's a picture on the bag that shows you where they go. It's an oblong hole just in front of the back wheels. close enough to the sides of the car that you don't have to reach far under.
    I had those in my glove compartment as well, but I put them in myself. Took about 15 seconds, after maybe 30 seconds of looking near the front tire because the picture was a little unclear. Once you find the hole, just push them in.
    And in case it wasn't obvious, this little task requires no tools.
