Rubber Plugs.
Discussion in 'Gen 2 Prius Main Forum' started by Gurmail, Jul 11, 2004.
  1. Gurmail
    Gurmail Member
    247
    Oakland, CA
    What do the rubber plugs do? I have seen in the pick up checklist that they should be installed or unistalled ?? I am about to pick up my Silver #7 this week!!
  2. jamarimutt
    jamarimutt New Member
    985
    I have the plugs stored in a plastic bag; obviously, the dealer did not not install them when preparing the car for delivery. I also look forwards to knowing what they do.
  3. Frank Hudon
    Frank Hudon Senior Member
    4,147
    these plastic plugs that you have in the bag are they about 1 3/4" by 1 1/4" and 12 in total?
  4. Gurmail
    Gurmail Member
    247
    Oakland, CA
    Rubber Plugs
    Yes, the ones I saw were like that. What are they for?
  5. Frank Hudon
    4,147
    they go in the bottom of the rocker panels on each side of the car. They just snap into place. I was hoping that jamarimutt would have look at his car and tell me if they were installed there or not.
  6. jamarimutt
    985
    Frank:
    I have two large plugs in a sealed plastic bag. I don't know what the plugs are for or what they are suppoosed to prevent.
  7. naterprius
    naterprius Senior Member
    1,843
    These are "body plugs." They plug two holes in the underside of the body. The holes are there to provide a tie-down point when flat-bad transporting the vehicle, like when new or otherwise. They are left out until dealer prep so they don't get lost.
    Nate
  8. tms13
    tms13 Member
    174
    Lochcarron, UK
    Business Ed. Plus
    It depends on the method used to tie the vehicle down for transportation, too. In the UK, where cars are required to be secured by their wheels to the transporter, the rubber plugs don't get used (the push-outs for the tie-down points don't get pushed out). But it's easier to supply every car with the plugs than to keep track of which ones need it and which don't.
  9. jamarimutt
    985
    Where exactly are these two holes so that I can try to plug them myself?
  10. terkar
    terkar New Member
    104
    Hendersonville, NC
    Yes...Where are these holes that need to be plugged located? Have had these two plugs in the bag for some time and have no idea what to do with them.. Help!!
  11. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    The Pre-Delivery Checklist
    PD016-03.pdf
    Has a diagram showing where they go.
    I don't know if it's here, but I had posted it over on the Yahoo 2-G Group files section in the Manuals Folder.
  12. drbob
    drbob New Member
    55
    Northern Michigan
    It's unsettling that so many prep guys around the US are slacking off. I have a bag of plugs in my glovebox, too!
    Dylan Murphy likes this.
  13. Joel
    Joel New Member
    108
    Houston, TX
    They're for eating, they make a tasty snack. :idea:
  14. richard schumacher
    7,663
    1,040
    United States
    Can you post a direct link to this diagram? I've been searching and have not found a picture showing the installation location for the plugs.
  15. naterprius
    1,843
    The spot is not hard to find. Get on your knee facing the rear wheel. Take your left hand, place your fingers just inside the pinch rail in the bottom of the car. (Pinch rail is where the nice colored part meets the rough colored part on the bottom of the car).
    The plug goes in straight up; laying flat, lengthwise with the car. The lip of the plug projects out onto the bottom of the car.
    Repeat for the other side.
    There are only two holes (like these) under the car. Once you find it, you'll know.
    Nate
