Rubbing or Bearing Noise, front end, during left hand turn.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by madog6862, Aug 3, 2014.
  1. madog6862
    madog6862 madog
    New Jersey & Naples, FL
    I am getting a rubbing or bearing noise when turning left. Noise not there when driving straight or right turns. Seems to be coming from front passenger side. Dealer has checked twice at normal services, nothing.
    2006 - 131,000 miles
    #1 madog6862, Aug 3, 2014
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    Passenger side wheel bearing may be failing. Pretty common.
  3. taylor_priusII
    taylor_priusII New Member
    17
    Morton, IL
    E-brake, chock rear wheels, ig-on, put in neutral, raise right front and spin wheel by hand.
  4. madog6862
    madog6862 madog
    On wheel bearings, are there an inter and outer bearing on each wheel. Should they be replaced both front wheels, Driver side and Passenger side at same time?
    What would be cost for this project, done by Dealer?
  5. Britprius
    Britprius Senior Member
    5,194
    1,912
    Herefordshire England
    The wheel bearings front and rear are complete hub units with wheel flange and studs. These are held in place by for bolts plus the drive shaft on the fronts. See link below.
    Wheel bearing
    John (Britprius)
  6. lokareddy
    lokareddy Junior Member
    toronto
    Technology
    have you got it fixed? what was the problem? how much you paid? plese reply i have exactly same problem with my 2005 prius...
