Ruined another battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Solman636, Jul 24, 2023.
  1. Solman636
    Solman636 Member
    99
    37
    Florida Panhandle
    Perfectly health battery is dead flat this morning. I was trying to install a rear view camera, and pretty sure I left the parking lights on trying to find a wire in the liftgate to tap into a couple days ago. The car was off, but I thought the lights went off after while on their own. Every few years I kill a battery, but in the past I thought it was trunk light. It has been so long I quit using the trickle charger since I drive more regularly now. What are main causes of this accidental complete discharge in gen 2? I've done it again..haha...whatever it was? What did I do wrong this time so I can avoid another $300 mistake. Hopefully, the battery will not be damaged too badly. Any advice appreciated. Thanks!
    52,923
    If it’s not the camera, you might have a phantom drain.
    Otherwise, it’s a light or bad door switch
    Solman636 likes this.
  3. Solman636
    Solman636 Member
    99
    37
    Florida Panhandle
    Will parking lights completely drain the battery or do they shut off after a while? Thanks for your advice! Never did connect the camera. The only thing I can find out of the ordinary is the parking light switch was on.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Yes and no, in that order.
    They are designed that way on purpose.
    Mendel Leisk and Solman636 like this.
  5. Solman636
    Solman636 Member
    99
    37
    Florida Panhandle
    If I understand correctly then the parking lights do not shut off. Please another question. In contrast the main headlights will turn off after a while with car off? Is that correct? If so I will have to be very sure to turn headlights either all the way off or leave them on to avoid draining the battery? Or is there a scenario where headlights will stay on indefinitely too...such as if turned on when car is in off mode? Thanks for you patience and the advice. :)
  6. Solman636
    Solman636 Member
    99
    37
    Florida Panhandle
    Did find this on earlier post which indicates there are certain procedures that can affect outcome. Some of these would be of interest to Prius campers who may turn things on and off from back seat and leave the car. LOL..saw a guy testing camping in new VW buzz ..and locked himself out at 1am with cold and mosquitoes and had to call wrecker. Thankfully, I have never had that problem. A seasoned camper would have had his pee bottle though..haha. Poor guy! How dismal. Anyway, I digress...found this:
    there are several other options to disable the headlights-auto-off feature. Did you test any of them for the park lights too?
    (1) After turning the ignition off, turn the light switch off, then back on to where you want it (Maybe open the driver door once before turning lights back on);
    or ...
    (2) Don't open the driver door, exit through the passenger door instead;
    or ...
    (3) Stay inside the car, don't open the driver door.
    If you must park alongside the road for a while, the emergency flashers will be more visible, run longer before battery depletion, and are never subject to the auto-off system.
    #7fuzzy1, Mar 14, 2019
  7. rjparker
    rjparker Tu Humilde Sirviente
    11,152
    6,989
    Texas Hill Country
    If you turn on the headlights or parking lights after the car is off, they will stay on.
  8. Solman636
    Solman636 Member
    99
    37
    Florida Panhandle
    Thanks, TX, will not make that mistake again!! I hope..haha... Battery charger got it back to 70% so far. Hopeful !
  9. sam spade 2
    7,035
    2,804
    2017 Prius c
    It is good to be hopeful.
    But I strongly suspect you will need a new battery.
  10. Solman636
    Solman636 Member
    99
    37
    Florida Panhandle
    Usually that has been my experience too, Sam. I just found battery receipt. I bought it just a year ago online from Battery Mart for $213, and it has a 2 year warranty. It hasn't had much use at all, and most of that time was on a trickle charger. Maybe due to fact it is like new and the fact that it did take a charge to 100% is a good sign. I'll take it off the trickle charger in a day or two and see how it holds the charge before I get out on the road again. I always keep a small 12 v AGM battery made for a UPS onboard so I can at least start and get underway in the event the battery dies.
  11. sam spade 2
    7,035
    2,804
    2017 Prius c
    I hope you take THAT one out occasionally and charge it too !!
    A battery that new with only one deep discharge might well be OK still.
    Note: There is really noting to be gained by connecting a tender when the vehicle will be driven
    regularly.....like twice a week or so.
    By connecting it every day, that will ensure that it starts the first use each morning, even AFTER it has effectively failed.
    Then it won't start the second time to get you back home.
  12. Solman636
    Solman636 Member
    99
    37
    Florida Panhandle
    Thanks, Sam. Good advice. Yes, I charge the little UPS battery periodically, but now that you mention it I'll make a calendar reminder just to be sure. Time slips away! Also, agreed that the real test of the main 12v battery now that it is recharged is to not use the tender and see how it hold up with only a charge or two a week. Now that the tender light is green I'll follow your wise suggestion. Again, thanks for your feedback and advice! For what it is worth, I think the one year old battery survived, and I learned a lesson about the arcane secrets of the different modes for the parking light through this exercise.
  13. sam spade 2
    7,035
    2,804
    2017 Prius c
    I thought I could resist saying this, but it seems as I just CAN'T:
    You actually can tell if the lights have been left ON just by......
    looking at them !!!
