Rumbling and P0401 EGR code gone with fuel change
Discussion in 'Newbie Forum' started by Laura Eastman, May 26, 2019.
  1. Laura Eastman
    Laura Eastman Junior Member
    Lincoln, NE
    2010 Prius, ~133k miles. Bought used at 126k mi, previous owners seem to have taken good care of the car. I usually put Shell 89 in it because I was going off the "88" listed in the owner's manual. I read somewhere on here that that was a misprint and it was suppose to say 87. So I put 87 in. A short while after that on the first (and only) tank of 87 I got horrible rumbling on startup and while idling. Car threw the P0401 EGR code. I decided to do the next fill with my usual 89, a bit after that the rumbling was only at start up and wasn't so horrifying. Filled it up again today with 89 and the rumbling is completely gone.
    Toyota won't replace the EGR valve in accordance with the enhanced warranty because it is a previously salvage title and I am not in a California emissions state. (That is a whole other story with the the CSR telling me it was covered and then the dealer refusing to honor it, they did confirm that the EGR valve should be replaced)
    Doing research on here I had decided to replace the PCV valve, clean the intake manifold, throttle body, EGR pipe, and have the EGR valve and cooler cleaned (or replaced if they won't clean it). I have already bought all the tools to do the PCV to EGR pipe, but I was going to pay for the EGR valve and cooler because we have an apartment and I don't want to risk spilling coolant. It also looked like that part was much more intensive.
    Now that the rumbling is completely gone, and I suspect if the engine light is reset it won't come back on, should I still pay to have the EGR valve and cooler fixed up? I will still do that DIY work I intended on doing.
    Prius_Angie likes this.
    52,671
    i think yes, but will leave it to those who have done it. no idea why octane would change anything.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    If you’ve not done the cooler, there is still restriction in the system:cool:.
    Some of the work can be coincidental, but the whole circuit needs to be touched;).
    But at 133k miles, I’d also look to do the catch can install, then you should be good for a bit(y).
    #3 Raytheeagle, May 26, 2019
  4. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Yes definitely change it. Read the horror stories of people having blown head gaskets in the gen 3 threads.
    Prius_Angie and Greenteapri like this.
  5. Greenteapri
    Greenteapri Active Member
    330
    387
    Cypress
    Rent a garage with tools and knock that EGR carbon out! Your Prius is begging for some TLC. Find out if the sparkies were replaced by the previous owner.
    Prius_Angie and Mendel Leisk like this.
  6. Mendel Leisk
    42,165
    Some info for DIY, and yeah, I'm starting to "boiler plate" this:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    Good thread:
    EGR & Intake Manifold Clean Results | PriusChat
    And to keep it clean, an Oil Catch Can is a very good idea:
    Oil Catch Can, Eliminate that knock! | PriusChat
    Somewhat tools worth having, for EGR and intake manifold cleaning:
    E8 Torx socket (mandatory)
    E6 Torx socket (optional, but good to have, to remove the throttle body studs from intake manifold)
    3/8" ratchet wrench, regular and long handle, flex head, you can never have enough
    1/4" ratchet wrench, or 3/8" to 1/4" reducer
    Ratchet extensions: you can never have enough
    Long needle nose piers, straight and bent tip
    Ratcheting 12mm box wrench (optional, but makes disconnection of the EGR cooler from exhaust easier)
    Torque wrench (3/8" and 1/4" both good to have)
    Floor jack and safety stands (or ramps): basically some method to raise front, if you need to take underpanel off, which you may need to, both for access and to recover dropped items.
    Greenteapri and Skibob like this.
