Rumbling noise from 45 to 55
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Jan 14, 2017.
  1. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    I purchased my car in Illinois, it was a fleet vehicle in Iowa according to the carfax. Prius III W/ nav
    I live in Colorado now...
    The rear hub went at around 110,000.
    $56 dura international hub still going strong.....
    bisco and Raytheeagle like this.
  2. Taxi/Limo
    Taxi/Limo Active Member
    526
    107
    The guy at parts said they don't sell bearings and hubs that often
    Nexus 6 ?
  3. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    How many miles on your Prius now?
  4. Jimi1976
    242
    124
    Denver, CO
    125,xxx
    Raytheeagle likes this.
  5. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    I assume the Dura International assembly came with the speed sensor connection point? $56 seems really low, compared to the others.
    Sounds like you are happy though and it is working well.
  6. Jimi1976
    242
    124
    Denver, CO
    Yes, and yes.
  7. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Did you replace in pairs, or just the problematic one?
  8. Jimi1976
    242
    124
    Denver, CO
    Just the one.
  9. grnd0
    grnd0 Member
    42
    26
    I got the $60 Dura from Rock Auto. Did it myself, easy.
    Jimi1976 likes this.
  10. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    How many miles since you replaced yours?
    And still satisfied?
  11. grnd0
    grnd0 Member
    42
    26
    Only about 4,000 miles. Just did it a couple months ago. Working fine.
  12. Taxi/Limo
    526
    107
    Is OEM really the best then ?
    Nexus 6 ?
  13. Jimi1976
    242
    124
    Denver, CO
    At this point, I would say NO.
  14. Taxi/Limo
    526
    107
    Anyone want to buy a brand new wheel bearing and hub.
    These are NSK OEM purchased directly from a respected shop. The reason I am offering because I may buy two and may not need the second one and shop will not take returns. I pay 139.00 and will sell for the same to someone in the San Francisco Bay Area
    Nexus 6 ?
  15. Taxi/Limo
    526
    107
    No one interested so far in that spare bearing OK
    Can anyone tell me the torque settings when putting the rear wheel bearing assembly back on 2010 Prius
    Thanks
  16. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    66 ft-lbs.
    Mendel Leisk and Raytheeagle like this.
  17. Mendel Leisk
    42,352
    Repair Manual excerpt attached, nothing extraordinary, agrees with the 66 ft/lb value.
    Comments, and this is from someone who hasn't done this, just reading about other's experiences:
    1. Disconnect the speed sensor wire before trying to break the hub free: it can end up flying off, tearing the connector off.
    2. Someone's suggested to put a threaded rod with nuts and washers through the large diameter holes in the flange, then start screwing the nuts so that it acts like a spreader bar, eventually pops the hub free.
    3. With the brake rotor, a pair of M8x1.25 (by maybe 25 mm, fully threaded) bolts can be screwed into threaded holes in the rotor, to help pop it off. (this I have done)
    4. Disconnect and isolate 12 volt negative cable before removing rear brake caliper, and take care when reasembling that the pin on pad backing plate is locked between the spokes on face of caliper piston. And is well seated thus. Do multiple pedal pushes, then reconnect 12 volt, then a test drive, and only then use parking brake, if needed. (Repair Manual excerpt on brakes attached)
    #57 Mendel Leisk, Jan 27, 2017
  18. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Thanks for the links:). I actually used them with @Taxi/Limo today. Found them before you posted though. Job done successfully(y). Maybe @Taxi/Limo will post some pics that he took.
    The interesting piece if you have to do this is the speed sensor removal. It has a plastic support shroud around the sensor that has to be removed first. All the repair manual says is to remove the speed sensor and "be careful". Unfortunately we had to figure it out as we went, but got it done:).
    Also did trans drain and fill, inverter drain and fill, engine coolant drain and fill and lubed the caliper pins on the hub replaced.
    The pin wanted to not fit correctly, but we got it aligned properly;).
    Good deed for the day done(y).
    m.wynn and Mendel Leisk like this.
