Run away acceleration
Discussion in 'Gen 4 Prius Main Forum' started by kkayser, Jul 19, 2017.
  1. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    I find the Auto CC really easy to use and extremely accurate, foot brake cancels setting and accelerator will override setting. If you are in a 45 zone and it changes to 55, 10 upcklicks will do it. The car actually walks away from the traffic behind me. Always be aware that you know it's on or OFF. In OFF the car will not automatically keep distance or stop. So never assume it's ON.
    RCO likes this.
  2. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    I think almost every Toyota has had the unique cruise control stalk since the early 90s. They just changed it on the 2018 Camry. It's a bunch of buttons on the steering wheel.
    RCO and alanclarkeau like this.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Yes, I read about it - a local Motoring journalist did an overseas drive, and one of his most positive comments was that they'd finally ditched the C/C stalk!!!
    'LectroFuel and RCO like this.
  4. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I did the same as OP first time I used it, very disconcerting if you're not expecting it, that'll teach me to read the manual first. With old style CC you could use the stalk or switch as a hand operated accelerator, holding it until you reached the desired speed, with DRCC the stalk is basically a pre-selector for the desired speed, each flick is 5 mph on UK versions so it rises very quickly.
    RCO likes this.
  5. liquidtenmillion
    liquidtenmillion Active Member
    261
    194
    Easley, SC
    It's really simple when you think about it in terms of how DRCC works.
    You are not setting the speed of your car. You are setting the MAXIMUM POSSIBLE speed the car can go up to. You can set that to 80 way faster than the car can achieve that speed. If you are following behind someone doing 30mph, you can hold the stalk until your maximum is 120mph, you will keep going as fast as the guy in front of you, up to the maximum you set, 120mph.
    You can see this number as you change it. If the car in front of you is doing 50, and you hit the stalk and the little number shows 75, that is the max speed you could be doing if the car in front of you was going faster or didn't exist. You would have to see this number or else you wouldn't know what the car would accelerate to if the person in front of you moved.
    wrprice and RCO like this.
  6. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Another thing that's a bit embarassing is when on a multi-lane road like the motorway (freeway) or a dual carriageway, the car in front of you is approaching a slower moving vehicle and another vehicle is overtaking you, the vehicle in front of you pulls out into the next lane to overtake the slower vehicle in front of him, the DRCC then decides, lets fill that gap in front and accelerates up to the slow moving vehicle, in the process illegally undertaking the vehicle that was passing you.
    RCO likes this.
  7. Zythryn
    Zythryn Senior Member
    6,412
    4,415
    I think this all comes down to a more general issue.
    Cars change. If you don't buy a new car for 10-15 years, the new car is very likely to behave differently than the old one.
    Some of these changes are minor, some may be more significant.
    Standards change, regulations may change, etc.
    This is why it is important to get familiar with the manual.
  8. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    Many of the cruse control in the past would set it to the car speed. And the gen 4 does that to with a new set command. But if you hold the accelerate up the desired speed ramps up fast to another new set speed.
  9. alanclarkeau
    7,045
    7,593
    We don't have that law here - wouldn't work because so many idiots sit at under the speed-limit in the "fast" lanes. In reality, the slow (left for us) lane is the quickest.
    RCO, kithmo and jerrymildred like this.
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    LOL! I started reading your post before I looked at who wrote it. I got this far and looked to see if it was someone in Florida. :ROFLMAO:
    alanclarkeau likes this.
  11. Andyprius1
    2,327
    859
    Cool CA
    My 59 Peugeot had stalks on both sides as many other European cars at the time. Of course no CC ....yet
    'LectroFuel likes this.
  12. felixthekat
    felixthekat Junior Member
    28
    34
    Sacramento, CA
    I have serious doubts the car actually accelerated on its own. Please do not blame your own user error on the car. User error in people who do not understand how car tech works, was the very same cause in the "unintended acceleration" Toyota was sued for several years ago.
    pilotgrrl, RCO, Andyprius1 and 2 others like this.
  13. Andyprius1
    2,327
    859
    Cool CA
    Your right it does not accelerate on its own, the driver accidently sets a higher speed than intended. I have done this a few times now. easily corrected tho, just tap the brake. and do a reset.
    RCO and bisco like this.
  14. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    Run away acceleration in a Prius, not the scariest thing in the world. You've got some time to react, think of options, make a few phone calls if you have to.
  15. bisco
    52,878
    true story.
    RCO likes this.
  16. 'LectroFuel
    880
    673
    If you moved the steering wheel left and right really quickly to slow the car down you'll probably never go above 40MPH.:ROFLMAO: My gen 2 was "trying" to run away while stopped at a stoplight. I had my foot on the brake so it was just revving. Probably not good for the car, but restarting it fixed it. Hasn't happened since. The accelerator wasn't even stuck on the floor mat.
    #36 'LectroFuel, Jul 23, 2017
  17. Andyprius1
    2,327
    859
    Cool CA
    Should not hurt it, Brakes always override accelerator. Probably all that happened is a bit more charge.
    RCO likes this.
  18. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    Why is no one talking about unintended braking? The first time I drove the i3, it did just that and the BMW guy who was riding shotgun didn't know anything about and said he'll have the mechanic look at it. Later come to find out that it's a feature. Now that I know how it works, I wish all cars with electric drive of some sort have that. Don't blame the "that's how it works" on the car when it's clearly user error.
  19. 'LectroFuel
    880
    673
    How is "unintended braking" a feature?
  20. cproaudio
    2,401
    762
    CA
    Single peddle driving. Release the accelerator peddle and the car brake it self to a stop so you don't ever have to touch the brake peddle under normal driving condition unless there's an emergency then you would have to slam on the brakes. For someone who has never driven the i3 like myself, this would qualify as unintended braking because I never intent for the car to brake itself when I release the peddle.
