Running E85
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by WE0H, Feb 24, 2012.
  1. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    If you don't have way to do a legitimate accelerated test, about 10 years.
  2. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    ...guess we need to use the real McCoy grain alky @200 proof.:D
  3. WE0H
    WE0H Senior Member
    3,247
    528
    That would be a bit lengthy test :( How long would it take to supposedly dry out fuel lines and other components?
    Mike
    iPhone :)
  4. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    What is an acceptable fuel line life for you?
  5. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Politics aside, what factors go into E85 vs. E10 pricing? Is there less state tax on E85? Does bulk ethanol vs. gaso price spread go into the equation?
  6. Former Member 68813
    3,524
    983
    US
    don't waste your time. other people did that for you:
    fuel pump after 3 years of E85:
    Fuel system after 3+ years on E85 - evolutionm.net
    Every car made after 1980 is made to tolerate ethanol as we used gasohol for many years.
    The difference in FFVs is fuel sensing and difference in injector timing.
  7. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Because a Mitsubishi Evo has the same fuel system, line, components, etc. as a Prius? Or, Toyota has been known to engineer and test their fuel system components for long-term 85% ethanol compatibility on vehicles not listed as being E85 compatible?
    Even the Prius c manual has a statement to not use E15 (I commented on it at http://priuschat.com/forums/prius-c...h-prius-c-manual-available-4.html#post1454717) and Toyota also opposes the use of E15 per http://www.toyota.com/about/environmentreport2011/02_energy.html:
    See my earlier post w/the video from Motorweek. Does the OP only plan to keep his Prius, when he buys one, for only 3 years?
    The Prius was made to tolerate 10% ethanol, not 85%, at least per the owner's manual.
  8. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Yup, Motorweek in the Gosses Garage (spelling) segment showed all the parts that ARE different between two GM cars, one "flexfuel" one not (same model and engine). It was quite a pile of stuff.
    If someone tells you different, ignore them. They are misinformed.
    They did another show comparing "fuel efficient" cars and trucks. In that one the GM PU "flexfuel" truck, running on E85, cost more per mile for fuel than if it ran on regular gasoline. Due to the terrible mileage it got. Now I'm -sure- someone will disprove this. They always do. ;)
  9. WE0H
    WE0H Senior Member
    3,247
    528
    I'll say 5-7 years as I keep my vehicles about that long.
    Mike
    iPhone :)
  10. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    key point also was
    I think this is for 100% E85 so the MPG hit for the blends that WE0H was using could be less. But the point is probably little need for running E85 from fuel cost savings perspective. Many of us would rather get the full MPG we can get on 100% gaso because 50 MPG looks so nice on the Prius display. Others feel displacing petroleum is the key objective and see no problem entrenching us in the <49 MPG purgatory due to E10+. :)
  11. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    38
    Santa Fe, NM
    Someone, please post pictures of destroyed fuel system components in late model Toyotas, caused by using high ethanol concentration.
    There is no meaningful difference between E10 and E15, so Toyota's statement (from marketing people) is bullsh1t.
    Somebody wants to run a long term test of >E50 in a Gen II, I have at least 1 complete fuel system that I will give you if you can produce a component damaged by such use.
  12. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    From a cost point of view, http://www.fuelgaugereport.com/ has the E85
    MPG/BTU adjusted price showing that there is no cost savings to running E85. After adjustment, E85 is more expensive.
  13. Gary in NY
    Gary in NY Member
    153
    Poughkeepsie NY
    I also posted this link where a story says E85 is only E70 in winter to improve cold weather performance. If this is true WE0H may not have been running straight E85 as he thought, and he may get different results in the summer when E85 really is E85.
    Since I keep my cars a long time I don't want to risk corrosion, so I'll stick to Toyota's recommendations. E85 isn't even available in my area, so this is a moot point for me anyway.
  14. Gary in NY
    Gary in NY Member
    153
    Poughkeepsie NY
    I watched that too, and it is a big pile of stuff. I'm sure it adds to the cost of the car. The fuel type sensor is a pure adder, and stainless steel parts and pretty much all the parts probably cost more too (I'd think all those parts would be used on all cars if they didn't cost more).
    Since it seems the Prius could handle E85 if Toyota wanted it too, but may add to the cost of the car, it might be nice if Toyota at least offered E85 capability as an option. Some people might be willing to pay for that. Or some might decide they'll run E85 anyway, without that option (like a few already have). If lots of people start doing this, and cars start failing as a result, it may give E85 a bad name (or give Toyota a bad name, as happened already with oil sludge, which may have sometimes been due to inadequate maintenance by owners, or as happened with unintended acceleration, some of which may have been due to driver error).
    Maybe this is one more reason Toyota doesn't want us using E85. They don't need anything else causing cars to fail and giving them more bad press.
  15. Gary in NY
    Gary in NY Member
    153
    Poughkeepsie NY
    That's for average prices, but will depend on local pricing variations. I think some cars do better with E85 than others too, depending on how well their fuel system adjusts. In my state diesel costs much more compared with gas than it does in some other states. I don't even see E85 here, so I can't compare prices on that.
  16. drew_flux
    drew_flux Junior Member
    73
    22
    sydney australia
    Err mike, try 13.5:1 static compression for a gen 2:D
  17. drew_flux
    73
    22
    sydney australia
    I have pump, hoses, injectors, filter all wraped up and ready to go incase of failure. If you want parts for distructive testing, Im at 120000km never ran on anything less than E20.
  18. seilerts
    3,326
    1,519
    38
    Santa Fe, NM
    Mike was talking about the CR of his SUV.
    The high CR of the Prius does make E50 +/- somewhat more compelling. The cost benefit has the potential for a favorable outcome.
  19. David Beale
    5,963
    1,989
    Edmonton Alberta
    The Prius CR is not that high. The intake valves are held open to "bleed" the air during part of the compression stroke. That's why it's called an "Atkinson cycle" engine (it's actually pseudo Atkinson cycle). Long stroke but not high compression. Service manual states "standard compression reading 128 PSI" which, if assuming 15 PSI atmospheric pressure, about 8.5:1, but it's probably just over 9:1 mechanical.
    That's for the GII, but I suspect the GIII is not too different. Don't have the service manual for it yet.
  20. WE0H
    WE0H Senior Member
    3,247
    528
    The reason some vehicles do not drop in mpg from running a blend of E85 is they run high compression motors. My Saturn Vue runs a Honda V-Tach :p motor which has a 10:1 compression ratio. It runs 16 mpg on 89 octane gas, 21.5 mpg on 50/50 gas/E85 and 19.5 mpg on a 3 gallon 87 octane/10 gallon E85 blend of which I have been running for 5000k or so miles. It kicks out a lean burn code on cold starts but does not kick out a code for warm running. I have reset the code once it was warmed up and drove for a couple hundred miles to see if it came back on and it doesn't. Once I let the motor cool so the next start is a cold start, it kicks out the lean burn code.
    I save $3.50 per tank fill compared to filling with straight gas not calculating the mpg as I get higher mpg on my blends. That $3.50 per tank is used to buy a gallon of milk and sometimes a custard filled donut :D
    There are sites that speak of low compression motors getting worse mpg with any alcohol in the gas and others that speak of the higher compression motors not decreasing the mpg with blends. I tried it and it didn't drop. I initially started out with a single gallon of E85 as I was scared that it would not run right but soon I found it ran fine.
    People who own GM vehicles will possibly tell about the soot collected on the rear of the car from simply driving it normally. It appears to me, anyhow, that GM tunes their cars to run pig rich. I know two of our GM cars, a Saturn Ion Redline and a Saturn Sky Redline both came from the factory running so rich that the back of the cars would collect black soot spots from driving them normally. I have since had ZZP tune my Ion so it runs clean and also can run E85 blends with the current 42 pph injectors or run either 92 octane or straight E85 with 60 pph injectors. I opted to save some money so I bought the 42 pph injectors. The Sky is Denise's and she likes it bone stock. BTW the Ion is being sold to buy my MY12 Prius. I am tired of pouring the gas money into the Ion and also tired of a go fast car. Enough is enough :p
    IDK, I don't want to argue one bit about the pros or cons of using blends but just wanted to see if anyone else here was running blends. It surely is good info that the Prius Chat people are digging up and posting :thumb: That's how we all learn something or get reminded of something we have read before. Either way it's all good.
    Mike :tea:
