Running wire through Firewall
Discussion in 'Gen 4 Prius Audio and Electronics' started by smalltimeart, Jun 23, 2017.
  1. smalltimeart
    smalltimeart New Member
    22
    Four Touring
    Anyone have any idea where the easiest place on a Gen 4 w/JBL would be to run a wire? Probably 4 AWG to the amp i'm going to be putting in. I've taken a look under the hood and around the gas pedal etc. and nothing seems incredibly obvious. I'm removing and completely bypassing all the factory head unit stuff along with the JBL amp. The sound is good, however, the functionality of the head unit makes me want to punch a baby.
    I've tried to find a harness to retain the factory amp but nobody has come out with anything yet to make it a plug and play solution. I don't mind doing some wiring but I can't even get a pinout or schematic for a Metra harness, or anything else for that matter.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Isn't the JBL integrated into the main computer(s) of the car in more ways than just being an entertainment unit? Will the car actually run without it?
  3. ChapmanF
    19,065
    If you're ok with doing some wiring, instead of looking for Metra's schematics, you could just use Toyota's wiring diagram and make your own adapter.
    Toyota's prices for the crimp terminals are high at the dealer; cheaper if you can find the ends of the correct harness at a salvage yard....
    -Chap
    smalltimeart likes this.
  4. smalltimeart
    22
    Four Touring
    it's actually not even remotely tied in. That's what i thought going into this project, but the more i learned, the more i realized they did the most cost effective thing they could. Basically it's a separate amp used for the audio that's stashed under the driver's seat, then the head unit controls certain portions of the MFD and very few features of the vehicle (such as unlocking one door or all the doors when you unlock the car).
    I did actually spend the money on getting toyotas schematics via TIS. Honestly it's worth every penny. You basically get everything that a dealer would get.
    The thing that threw me for a loop was when i looked at the aftermarket adapters to "turn on" the amp. It appears that the adapter interface is needed for cross/fade and all that jazz. I could totally be wrong. I'm an electronics technician with a healthy dose of experience in home theater but never really made it to car audio. It looks like iDataLink has a harness and adapter interface for this car even though Crutchfield says the interface doesn't work with my vehicle, but the harness does. It arrives tomorrow, and honestly if i can get the new head unit to work without rewiring an amp, I'll be happy. I listen to the occasional music but mostly podcasts. I just can't tolerate the half-a$$ed interface and performance of the current head unit. It's going to get replaced with this.
    CarJoying 10.1 Android 6.0 on Amazon, in case it doesn't load on here through links
    This thing is kick butt and has been sitting on my desk for the past couple weeks while i get it configured and research this project. I'll post some pics when it's done but quite frankly, at the cost, and functionality of what it does, I'm not going to miss "entune" in the slightest.
  5. alanclarkeau
    7,045
    7,593
    Sounds like you have an idea of what's going on. I have heard some horror stories with people changing things on their cars in recent years.
    I didn't bother with ENTUNE - my salesman whispered that it's not worth bothering with.
    I agree the JBL is poor, not up to 2016 expectations. Our JBL is even worse than yours to operate - it doesn't have buttons or knobs.
    Just a piece of dust-collecting glass with sensitive spots which are difficult to find when driving. Yes, there are a couple of buttons on the steering wheel, but still takes quite a few seconds to, say, drop the volume if the next PODCAST track is lots louder than the previous one, fast-forwarding a track is worse. And if my elderly Mum reaches across to change volume from the passengers seat just as we go over a bump - anything can happen - generally the POWER or APPS buttons.
    But I'll put up with it - buying a car is a balance of working out what good things outweigh the things the VOLVO/KIA/FORDetc I could have bought would have done better.
  6. jamiec123
    jamiec123 Member
    89
    75
    Ohio
    There is a grommet kinda in the middle but more towards the driver side in the firewall. You will need to make your hole through it from under the dash. You cannot reach it from the outside unfortunately. It is a total pain in the nice person to reach.
    I would recommend this tool so you can make your hole then slide the word through it at the same time. It will make your like easier, trust me.
    I just installed a single Memphis 12 and 500 watt power bass amp in my car.
  7. smalltimeart
    22
    Four Touring
    You sir, are a genius. I'm definitely going to give that a shot.
  8. smalltimeart
    22
    Four Touring
    Exactly, it's just a poorly thought out casserole of nonsense. I wouldn't have opted for it when i purchased the car but I have a staunch rule I stand by. Never purchase a brand new car. This one so happened to be certified preowned and had all the bells and whistles I was looking for. I'll post some pics of when it's up and running with the new stereo.
  9. lcastro
    lcastro Junior Member
    Dallas, TX
    2026 Prius Plug-in
    XSE Premium
    Let us know how iDatalink works for you! I am also interested on changing the Entune unit for something more useful with Android Auto. I've installed Kenwood stereos with the Maestro interface on other cars, but I am hesitant on how it will work on the Prius.
  10. smalltimeart
    22
    Four Touring
    Welp I finally did it. I got everything connected and up and running. This radio is AMAZING. It's basically a full android setup for your car. The sound is soooo much better than on the stock JBL h/u. I kept the original speakers and they perform far better in this system. I've attached a few photos and as you can see it looks pretty darn good.
    For the install part I had to get all the wiring diagrams etc from TIS and figure things out on my own. Unfortunately there isn't an easy solution for harnesses. I had to splice in and wire my own. Not necessarily a bad thing because I sincerely doubt i'll ever put the old h/u back in unless i'm selling it. In that case i'll just buy the connectors and re-pin and crimp the new ones on
    Even after contacting some guys who make all custom harnesses, they could only make half of what i needed. I think the iDatalink maestro etc may work with the non-JBL version of this car but the JBL unfortunately has some wacky connectors that just aren't featured on the adapter harness. Nor is there any firmware for that unit.
    It looks good, sounds good, and has a billion times more function than the stock Entune nonsense. Feel free to ask any questions. I'll be happy to answer. IMG_5609.JPG IMG_5610.JPG IMG_5611.JPG IMG_5612 2.JPG IMG_5612.JPG
  11. jamiec123
    jamiec123 Member
    89
    75
    Ohio
    So that head unit is so big that it covers up you vents a little?
  12. smalltimeart
    22
    Four Touring
    Just a bit. Doesn't interfere though. It doesn't really block anything, I could always mod it a bit but for right now it works for me.
  13. lcastro
    Dallas, TX
    2026 Prius Plug-in
    XSE Premium
    So... you kept the steering wheel controls? How about the vehicle customization settings? I guess they are no longer accessible.
    Can you share a little more about how did you manage to hook up everything?
  14. smalltimeart
    22
    Four Touring
    Actually everything is still accessible and the steering controls work just fine
    lcastro likes this.
  15. smalltimeart
    22
    Four Touring
    Is there anything specific you'd like to know about the install? It was definitely a learning experience
  16. bobthejedi
    bobthejedi Active Member
    137
    154
    SF Bay Area
    I don't have much to add only that this is pretty cool, If I were driving in the car more I'd consider this, but I'm fine with my mounted phone and basic usage of the crappy entune.
    Are you using the bluetooth functionality to connect phone to the head unit? looks like you can mirror phones to it.
    Sounds like you got the imaestro and dash unit and were able to link them together for the most part
  17. smalltimeart
    22
    Four Touring
    Actually the head unit pretty much runs everything. The idatalink and maestro stuff aren't compatable at this point. Luckily the steering wheel switches use old fashioned resistors and switches instead of canbus data so the head unit can just tap in and use it natively.
    Instead of using Bluetooth, the head unit has wifi so I just use my tmobile syncup hotspot. No need to pair anything or turn on the phone hotspot. Just get in and go. I drive a lot and this was definitely worth the price of admission. They do make more inexpensive ones that are a bit smaller and probably fit better in the dash. For around $350 you can get an amazing one.
  18. lcastro
    Dallas, TX
    2026 Prius Plug-in
    XSE Premium
    But then, you can no longer set the vehicle settings (Light settings, automatic door lock, energy monitor, etc.), right?
    If you can, how do you do it? I', guessing that involves tapping into the CAN bus, and using some software capable of talking to different ECUs in the car, a function I would expect from the iDataLink adaptor (which you already stated is not compatible with the Gen 4 Prius).
  19. ChapmanF
    19,065
    Techstream, or Carista.
    -Chap
  20. smalltimeart
    22
    Four Touring
    The only options that I can't get into are just as you said, selecting all doors to lock or just the drivers, and some light delay settings. Honestly, I've never messed with those. If I really wanted to I could do like Chapman said, get Carista and change it. However, neither of these really were of any interest to me. Also, any energy monitoring I get right from the MFD. I'd say it's a tradeoff that's 100% worth it and encourage anyone that's considering it, to just go ahead and do it. I fully endorse the CarJoying brand. They might be a Chinese brand, but they really do make a decent product and give a $hit about their customers.
    RCO likes this.
