Running wire through Firewall
Discussion in 'Gen 4 Prius Audio and Electronics' started by smalltimeart, Jun 23, 2017.
  1. smalltimeart
    smalltimeart New Member
    22
    Four Touring
    Actually I take it back, all those settings are available via the MFD. Looks like there's really no downside to dumping the entune system
    RCO likes this.
  2. Yippeekyaa
    Yippeekyaa Active Member
    137
    160
    North Carolina
    So where exactly did you find a spot to run a wire through the fire wall? I have to run a wire to the battery this weekend for a trailer light harness.
  3. Yippeekyaa
    137
    160
    North Carolina
    Found a solution but it required a bit of work. Removed the wiper cowl to gain access to the giant grommet in the firewall. Snaked a wire through the grommet and reinstalled everything. Took about 45 minutes.
  4. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    Can we assume the backup camera works?
  5. G23
    G23 Junior Member
    28
    Details on where the giant grommet is on the firewall and how to identify it? Did you have to poke a new hole in the grommet? Can u at least see it without removing the wiper cowl? Thank you.
  6. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    @G23 It'd be best to ask this on The GEN 3 FORUM. There is very little similarity with GEN 4, as it's on an entirely new chassis.
  7. Tideland Prius
    16,684
    Are you asking for a Gen 3 or a Gen 4? This is in the Gen 4 section. If you're asking for your 2010, you may start a new thread in the Gen 3 section :)
    alanclarkeau likes this.
  8. G23
    G23 Junior Member
    28
    Woops. I need to update my profile. I have a 2017 prius prime now. I assumed the location of the grommet would be the same as the gen 4 priuses. Here is a pic of what I think may be the grommet.
  9. alanclarkeau
    7,045
    7,593
    It might be best to ask on the PRIME FORUM - they're more likely to respond.
  10. Shahzad Nayyar
    Shahzad Nayyar Junior Member
    94
    25
    Pakistan
    How is the performance in broad daylight. I have a gen 3 but due to the angle of the panel, cant see a thing in direct sun glare 20200919_111732.jpeg
  11. Techmc
    Techmc New Member
    Los angeles
    thomassster likes this.
