Runs and drives but these codesC1319, B1421, B1423, C2310 /Open or short circuit in battery Circuit.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JIM777, Apr 22, 2025.
  1. JIM777
    JIM777 Member
    162
    24
    Ar
    This 2006 Prius has been sitting quite some time however mileage only 136,000 miles. I know it had some critters in it while sitting. It’s is throwing these codes and red triangle. I haven’t been able to clear these. idea what to go after At least two get red triangle off ECT. C1319, B1421, B1423, C2310 /Open or short circuit in battery Circuit. Appreciate the help thanks.
    Thanks
  2. JC91006
    16,651
    8,501
    if it's been sitting, you'll at least need a new 12v before you begin figuring out any other problems. The HV battery probably will be dead too
  3. dolj
    dolj Senior Member
    8,180
    4,167
    Wellington, New Zealand
    How long is "quite some time"? Months? Years?
    Replace or fully recharge the 12V battery, then clear the codes (after saving them first) and rescan the car.
    Before trying to start the car, check the voltages of the individual blocks on the hybrid vehicle (HV) battery and ensure there is not too much variation (as in less than 0.3 V) between each one. If the total voltage of the HV battery is less than 209 V, find a way to charge it to at least 235 V.
    Once the HV battery has been verified, you can attempt to start the car.
    If you still have the Cxxxx codes, you should pursue those. The B1423 code is an A/C code you should pursue it if you fix the Cxxxx codes; it is not a priority. The B1421 you can ignore if the codes were read out of direct sunlight. It is simply telling you it did not detect bright sunlight. You will notice it does not set a warning light on the dash, either.
    I hope that helps.
    #3 dolj, Apr 23, 2025
    Brian1954 and MAX2 like this.
  4. JIM777
    JIM777 Member
    162
    24
    Ar
    Thanks much!
    Going after the c2310. Somewhere on here I found individual testing transmission control. Testing harness connector transmission control ECU assembly and P con. Fuse which I found to be good. Was told that could monitor transmission control on text stream. Not sure of procedure going to post picture of screen if anybody knows if this can be done. To test for short or bad connection. One spot I read red triangle blank on and off according to bumps was hoping to monitor on computer and wiggle wires. Appreciate any help thanks.
  5. MAX2
    MAX2 Senior Member
    1,436
    481
    101
    Third planet from the Sun
    Have you performed a full scan of all systems using Techstream?
    What errors remain?
  6. mr_guy_mann
    mr_guy_mann Senior Member
    3,939
    1,900
    NJ-USA
    The "Transmission Control system" on a Gen2 Prius is a fancy name for the ecu and motor that engages the parking pawl. This prevents the car from rolling away when you turn it off. It disengages the pawl when you have the car "ready" and shift into drive or reverse.
    The Techstream data screen shows 0V for "Battery Voltage". A not uncommon cause for that on a Gen2 is a corroded connection in the underhood fuse box. (underneath a black plastic "shield")
    The usual repair is to bypass the connector by splicing the two blue wires together.
    Brian1954 likes this.
  7. JIM777
    JIM777 Member
    162
    24
    Ar
    Spotted torn up wires below fuse box most ground wire removed inverter found several chewed through wires underneath inverter one being the small blue that goes to ECU transmission control. I Guess where this thing was sitting they had some serious rats. Has anyone ever replaced the positive wire from Battery to front fuse box? Any suggestions thanks. Gen 2 of course.
    Appreciate y'all have a great evening.
  8. JIM777
    JIM777 Member
    162
    24
    Ar
    Hey fellow from Missouri showed me this link helped a lot. Guess that's the show me state :) hope this information helps someone else in the future.
    P Lock C2310 Fix Fixed Solved Solution | PriusChat
