Runs rough after EGR cooler clean
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mattbatson, Jul 23, 2019.
  1. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    2011 with 150k miles
    Just bought the car
    Cleaned the cooler...following along with the nutzaboutboltz video
    Got it all back together except for the wiper tray as I wanted to make sure it ran
    Started it up and engine is running pretty rough
    Should I just keep idling it till it clears up?
    Went over electrical connectors and everything and it all seems to be reassembled correctly
  2. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    Oh I also did the plugs
    But that was really straightforward
    All seems fine
  3. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    Did the rough idling clear up? I remember when I started mine after putting it all back it was rough for a minute then calmed down. I think it was from the coolant recirculating and air pockets being pushed around and out.
    Raytheeagle and mattbatson like this.
  4. JC91006
    16,871
    8,619
    Did you plug back all the connections? If you cleaned the maf sensor and throttle body, you'll need to reset your 12v battery
  5. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    Ok
    I’ll try disconnecting and reconnecting the battery
    All connectors seem correct
  6. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    I was thinking the same
    Lost a little coolant
    But refilled the reservoir and left the cap off
    Was going to get it up to operating temp and make sure any air pockets bled out
    But was uncomfortable leaving it running in case I would cause damage
    mikey_t likes this.
  7. mjoo
    mjoo Senior Member
    1,163
    1,333
    Michigan
    Any codes?
    Pixel XL ?
    Raytheeagle likes this.
  8. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Maybe you are losing compression through the improperly tightened spark plug
  9. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    Thanks everyone for your responses I had noticed after letting it sit overnight when I started it in the morning that it was idling slightly less rough
    so right away I figured that it was just trying to blow brake cleaner and so forth out
    so I let it continue idling and sure enough it cleared up after about five minutes
    mikey_t and Merkey like this.
