Rust on Inside of Airbag on 2011 Prius! Suggestions?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sidewayzgt, Mar 31, 2017.
  1. Sidewayzgt
    Sidewayzgt Junior Member
    Los Angeles
    I just pulled my airbag off to replace the spiral cable and noticed this rust on the back of the airbag. Is this just a plate that I can pull off and clean? The rust seems to be light. Should this happen to a 2011 gen 3 or any airbag? I called the dealer and they want to charge me a diag fee to look at it. What should I do? Suggestions?
    #1 Sidewayzgt, Mar 31, 2017
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    That's light, and if it were on mine, I wouldn't worry about it. It appears to be cosmetic, and unlikely to affect function.
  3. Sidewayzgt
    Los Angeles
    Is it ok to take off the plate and clean it? Should I leave it alone?
  4. xliderider
    7,869
    3,116
    Honolulu, HI
    OCD much lol. Leave it alone man. ;)
  5. xliderider
    7,869
    3,116
    Honolulu, HI
    Let us know if you see corrosion in the spiral cable assembly as well.
    I'm beginning to think that someone was spraying cleaner or something on the wheel and got some liquid in there.
  6. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    If you clean it off let us know if you survive. ;)
    -I- might spray some paint on it but I would -NEVER- try to clean it. It's a bomb, you know that, right?
    xliderider likes this.
  7. Sidewayzgt
    Los Angeles
    I will leave it alone lol
