Rusted rear caliper slide pin question
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gboss, Oct 8, 2024.
  1. gboss
    gboss Member
    173
    63
    Mountain Town in CA
    Serviced all my caliper slide pins and found one on the rear that was seized due to what I guess is rust + some kind of buildup. The pads are at least double the width of the rest of the car, so I know the brake wasn't being activated. Broke the slide pin free and then sanded off most of the rust / gunk that I could see:
    Then, liberally applied grease and began to work it back into the caliper. At first it felt like a sandy grind when working it in and out (maybe that's rust on the inside of the caliper?), but it seems to function decently now. Not as perfect as the others, but it moves. Is this okay to use for a while?
  2. burebista
    burebista Active Member
    189
    130
    Romania
    What kind of grease? You need lithium soap-based glycol grease.
    This is from Toyota
    You should clean inside of caliper and with slide pin already cleaned I'd say you're good to go. :)
    gboss likes this.
  3. Tombukt2
    Tombukt2 Senior Member
    13,809
    2,504
    Durham NC
    Yeah I put mine in an outdoor dishwasher that's got scalding hot water running to it It's just used for car parts it's an old Bosch predominantly water and cascades still go through it today and it will bring things out of there whistle clean You've got to put metal preservative on the business as soon as it comes out as rust will form almost immediately usually I have new rubbers for all the boots and things whether they're Toyota branded or not they'll work and won't have bad reactions with the rubber grease
  4. ASRDogman
    ASRDogman Senior Member
    8,042
    4,075
    Spray it out with brake cleaner, then a rag with a small screw driver to clean it out.
    Then dry it out and lot's of grease. I much move freely and easily. You may have to
    replace the guide pins.
    And while you are at it, you should do all 4 calipers....
  5. Kenny94945
    Kenny94945 Active Member
    863
    439
    Sausalito
    2016 Prius v wagon
    Yes, good to use.
    FWIW I recall reading that the maintenance of lubing these pins is a good thing.
    Yet when to lube? Maybe every 30,000 miles, at a min. 60,000.
  6. ASRDogman
    8,042
    4,075
    I believe it's 50,000 to "check and lube as needed".
    But since you are 95% of the way there, it's only a minute or two to remove it
    and clean it up.
    gboss likes this.
  7. Mendel Leisk
    42,259
    In the Toyota USA Warranty and Maintenance Booklet there's a couple of statements about brakes: every 5k miles (presumably in conjunction with tire rotation) they say to "visually" inspect the brakes. This is replaced, at 30k, 60k and so on, by a statement to "inspect brake linings/drums and brake pads/discs" (the first a hold-over from second gen rear drum brakes).
    They don't go into any more detail, and the Repair Manual is not a lot of help, say having a section specifically for brake "inspection", what it entails. But anyway, just talking among ourselves, perhaps:
    pull the calipers off every 30k, clean/lube and reassemble the pads/shims, clean'lube all contact points between caliper and pads, and just move the caliper pins in/out, see that they mover freely and smoothly. Then every 60k, also pull the pins, clean and relube.
    Brake section of Repair Manual attached, for reference. Lots of info, but again, no specific section saying this is what you should do for brake inspection. It's more of a complete tear-down, which I doubt happens much.
    gboss likes this.
  8. Siward
    Siward Active Member
    314
    128
    Toronto
    I had the same problem. Rust only matters if it gets in the way of the operation of the brakes. It is perfectly fine sanding off the rust and putting it back so as long as it operates. You also aren't sanding it to the point where structural integrity is concerned.
    However, rust particles left over will likely lead to rust again. In the end, I just replaced mine with an brand new aftermarket Carlson caliper pin. About $8 and I will have to worry less about the brake seizing again. My labour cost to changing the brakes is more than what a new pin is worth. The pin can also cause uneven brake pad wear in which case you have to replace more parts.
    #8 Siward, Oct 11, 2024
  9. gboss
    gboss Member
    173
    63
    Mountain Town in CA
    Oh yeah. The pads on the RR (shown in the picture in the OP) were at least double the width of the brake pads on the other wheels/axles. I'll replace all of the pads when the other three get to that point...still have 35% left after 111k miles.
  10. ASRDogman
    8,042
    4,075
    Sooo, what did you do? New pines? Cleaned the original ones and reinstalled?
    Did you clean the caliper where the pins go? How did you clean them?
  11. gboss
    gboss Member
    173
    63
    Mountain Town in CA
    I just followed the NutsAboutBoltz video - cleaned pinned and applied heavy lube. Then worked it in and out a bit.
    ASRDogman likes this.
