S-Flow Back Seat AC?
Discussion in 'Gen 4 Prius Main Forum' started by 1stPriusLA, Oct 17, 2016.
  1. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Perhaps it's just doing what you wanted, rather than what you thought IT thought you meant! ;):whistle:
    Coast Cruiser likes this.
  2. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    How did you know I spilled my coffee yesterday? All over my "fine white china." :( The girl didn't put the lid on tight.
    That's why I always put a coat of wax on my china.
    RCO likes this.
  3. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Lol, sympathetically. :ROFLMAO:
    BTW, in cockney rhyming slang, a China is your buddy - mate (China plate, get it?).
    So was that a bikini wax you put on your buddy?
  4. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Interesting - on S-Mode, mine only blows from the 2 vents on the driver's side, unless there's someone in the passenger's seat.
    Possibly the sensor in your passenger seat is faulty, I'd assume the same sensor which reminds you the passenger hasn't done up a seatbelt. Does it remind you if the passenger hasn't done up her belt?
  5. Coast Cruiser
    2,267
    2,571
    Yes, the seatbelt sensor is fine. I see the icon on the dashboard display.
    I am OK with air coming out of all four upper vents. I think it cools the car better. I won't be using the S flow button, I just wanted to test it out today.
    alanclarkeau likes this.
  6. Colin Jones
    Colin Jones Member
    99
    174
    Aberdeen/UK
    Business Edition
    I think its a bit more clever than that. If the temperature in the car is way off it will use both sides until it gets to temperature that it then wants to maintain where driver side only will kick in - even if nobody is in the passenger seat.
    pakitt, RCO and alanclarkeau like this.
  7. Coast Cruiser
    2,267
    2,571
    Colin, are you talking about the AC "auto" mode?
    Anyway, I just think it's another Toyota gimmick. I got four nice vents on the dashboard, and I want air coming out of ALL four vents. :D
    (so I am actually glad that my S-flow is not working.)
    RCO likes this.
  8. alanclarkeau
    7,045
    7,593
    Ahh - clever - I had wondered at times if it was working right, but usually by the time I check it out, it's "righted" itself, but that makes sense that the AUTO mode is sorting that out. Unfortunately, you can't see which mode it's in till you press the S-Mode button and it displays what it's up to. Going for a longer run on Saturday, so I'll experiment.
    RCO likes this.
  9. Tideland Prius
    16,674
    Works for those with dual-zone auto climate control. US/Canada get single zone :(.
    You can check via the MID. Use the right D-pad to cycle through the menus until you get to "Climate"
    You may have to scroll down (or up) to the next page. I think that one shows S-Flow.
  10. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    I noticed that S-Flow takes a while to engage and it will record also if doors other than the driver's have been opened. Moreover as Colin said, it might use vents in different ways as just "driver only" depending on the inside and outside temperatures and desired temperatures.
    About Toyota making it complicated, I think the OP should go into a BMW or any other car. Toyota in comparison is children play. Everything is quite intuitive.
    I'd say, activate S-Flow and simply let it do its job. ;)
  11. Kuluz4Dayz
    Kuluz4Dayz Junior Member
    Hawai‘i
    Four Touring
    S-Flow is more noticeable while driving / car in motion. I’ve noticed that with S-Flow activated to Front Priority with the driver and a passenger in the front seats the AC will blow to the front vents when set to face.
    I’ve noticed when the passenger leaves the car you will hear the passenger vent (closest to the passenger door) close and it automatically goes to Driver Priority. Sometimes air will still blow out from the passenger vent closest to the passenger door when it’s on fan and AC is off.
    With Driver Priority on and you’re driving without a passenger in front and you reach over to the passenger vent (closest to the passenger door), the vent will be closed.
    When you stop and pick up a passenger the vent will automatically open. Listen carefully and you’ll hear the airflow pressure and vents opening.
    Since2002 and RCO like this.
  12. namuramc
    namuramc New Member
    Malaysia
    2022 Prius
    Hi everyone, hope don't mind if I resurface an old thread. Just got my hybrid recently and was actually checking out the S-flow mode. I was wondering if S-flow usage has any impact on the hybrid battery temperature as the rear air conditioning vents are deactivated (no air flow) when there is no one in the rear seats?
    Looking forward to hearing your thoughts on this. Thanks everyone! :)
  13. Doug McC
    Doug McC Senior Member
    1,087
    428
    Midwest
    2022 Prius
    We’ve actually tested the air flow in the different modes over different conditions (AFTER READING THE MANUAL, which seems to be an unusual skill ), and lo and behold it actually works as the manual says in the 2022 nightshade XLE. So, yes air flow will be restricted to the rear floor area, resulting in less air flow directed at the traction battery air inlet! BUT WAIT!!!! OMG, maybe that’s why those uninformed design engineers at Toyota (who CLEARLY have no idea what they are doing) installed a fan in the duct work for the cooling system of the traction battery.
  14. Tideland Prius
    16,674
    The Prius has a fan so it will draw in air as needed.
    Plus, S-Flow for the rear only works with the heater as there are only heater ducts for the rear seats (under the front seats). There are no A/C vents in the rear in any Prius so it's a moot point in the summer. It just cycles between Driver only and Front Seats.
  15. Doug McC
    1,087
    428
    Midwest
    2022 Prius
    Interesting: thenToyota needs to rewrite the OM for the 2022 US models starting on page 430 through 443 and perhaps we should take ours back to the dealership to have that airflow coming from underneath the front seats in to the rear seat area “corrected”. I wonder if that would be covered under the warranty;).
    dacoobob and Tideland Prius like this.
