Sabertec Blade - any good on a Prius?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Pegasus_, Aug 16, 2008.
  1. carguy_12
    carguy_12 New Member
    33
    Well its 700 mb of information. I'm not exactly a website builder and most if not all of the information is available on their website anyways. I just wanted to answer specific questions. I saw plenty of them here already, but I wanted to start fresh. But, I can answer any of the previous questions mentioned as well.
    I sat at these guys booth for about 2 hours (LOL). I feel like an expert and they offered me a less then full price sample so I could see it for myself. But, after seeing all the liscensed testing that has occurred, I feel like I can champion the product. Not to mention, all the sales guys have them on their cars and a lot of celebrities are running these things now.
    On the whole first time poster thing. I agree. I specifically joined this site to counter the arguments listed above. You were the top result on sabertech blade searches from what I could tell. Its kind of like slick 50. Everyone called it a snake oil for years until they figured out it actually works. The only problem with that product was the teflon could gum up your oil filter (and thats really bad).
    But, I am not afraid of any question.
  2. butchbs1985
    butchbs1985 Taking things apart is fun!
    225
    ChicagoLand
    2013 Prius v wagon
    As others have said, welcome to PC!
    First, observations:
    If you need a place to put the files, PM me for FTP information. (I'm not sure if PC has FTP space available for such data). I would be happy to host the files.
    Can you really consider yourself an expert after two hours? I don't know that I have ever been willing to 'champion' a product after only two hours. Much less a product that I have not tried. (Based on your previous post stating that you had not received yours yet).
    - Of course the sales guys use them. When a potential client sees them using the product, they are reassured that the product is legit. If customers are convinced, there will be more sales. (Isn't that the job of a sales guy)?
    - I consider celebrities to be authorities on restaurants and social events. Not so much automotive efficiency / mechanics / or much else. (with select exceptions). Do you see people asking Jessica Simpson for example how to change their oil?
    Agreed. This product does have similarities to Slick 50.
    -Similarity: Slick 50 gummed up oil filters while this will eventually plug your exhaust. Even a clean filter is a significant airflow restriction.
    - After a quick Google search, I'm fairly confident that you will find equal amounts of people who believe that Slick 50 is a scam and those who believe that it works. See this as an example: http://priuschat.com/forums/care-ma...sing-slick-50-similar-additives-in-prius.html
    -Are you Sure you aren't on the payroll? Seems like a lot of work for a social community that you have no real ties to / interest in prior to this product.
    Good for you! Here's mine:
    "3. BLADE decreases emissions and increases fuel economy by increasing the Volumetric Efficiency (VE) of your engine."
    I don't know anything about Volumetric Efficiency, but what I do know came from this web page. I also found that the web page could be contradicting itself when it states:
    "A big difference between the “gas wave†and the “energy wave†is that the energy wave travels about 5-times faster than the gas wave—at a rate of approximately 1,500 feet per second.When the energy wave travels through the exhaust system, it encounters obstacles, such as bends in the manifold, or the catalytic converter. These obstacles cause the energy wave to “bounce†or “revert†backwards in the form of a “reversion waveâ€.Reversion waves transmit energy back towards the engine. At supersonic speeds, it doesn’t take long for a reversion wave to reach the engine’s exhaust valve, which is still in the process of releasing the much slower-traveling wave of exhaust gas. When a wave of reverted energy encounters the gas wave, the more energy intensive reversion wave forces pressure upon it—pushing, or “backsliding†some of its gas back into the combustion chamber. And this is how reversion waves create backsliding! And backsliding is a major cause of pumping loss."
    So since when this "energy wave" encounters obstacles, the resulting bounce / reversion wave creates backsliding. Wouldn't the additional filter on the end of the exhaust provide yet another obstacle thus increasing the "backsliding"?
    Web page also states: "BLADE increases volumetric efficiency by reducing pumping loss and backsliding."
    OK... Where's the data? I am now so impressed by their description of Volumetric Efficiency that I have forgotten that you neglected to reveal how your device increases the volumetric efficiency.
    In your defense, they do have data elsewhere on the website. The website indicates that the data is in PDF format but it was actually Jpeg. (Perhaps they need a new web developer as well). I took the liberty of converting the files which are attached to this post.
    Note that the test results carry the message "The emissions numbers on this vehicle are small to begin with therefore any percentage changes have to be viewed with this in mind".
    Where's the remainder of the 700 MB of data? The website does not contain much convincing material at all. Please let us know where we can view the data.
    Again, I volunteer my FTP site if necessary. I commit to presenting ALL information provided without alterations or bias.
  3. dogfriend
    7,512
    1,185
    Carmichael, CA
    That's all I need to know. Thanks.
  4. carguy_12
    33
    Good morning. I don't mind uploading this information to your ftp. Get with me about that. I don't consider myself an expert on the blade at all. I consider myself an above average mechanic when it comes to exhaust streams and how they actually function.
    Lets get something straight. I am not on the payroll of sabertec and I am not doing this for profit. As someone in the automotive business, I can tell you that I highly doubt anyone from any company championing a new product would go on forums and post. It is a garanteed mess especially if your product does not work.
    I have gone to SEMA and APEX show for the last 6 years looking at all the new fuel economy savers. This product stood out to me because unlike many of the other products that are exhaust restrictors, this one worked in concept as well as testing.
    So to get to answering your questions.
    Are you familiar with headers for performance vehicles and what they accomplish? Headers increase performance of some cars by allowing the reversion wave to travel farther along the exhaust system before encountering an obstacle. They also help remove more exhaust gases via increased capacity.
    So, there are already products out there that increase the reversion waves travel distance which in turn creates better volumetric efficiency. Hopefully we can agree on that. If the reversion wave takes twice the distance that it was taking before, you are gaining a volumetric benefit as it is taking more time for that reversion wave to reach the exhaust valve and "backslide" gases into your combustion chamber.
    Every object along the exhaust system with any impeding devices will cause a reversion wave. This mostly consists of catalytic converters and mufflers.
    What the blade does is create an effect called exhaust scavenging. The exhaust stream moves in pulses. These pulses have an effect of going forward, then moving backwards. This is due to vacumn created in the combustion process and the reversion wave creating backsliding. The blade does create pressure in the exhaust system. That is true. But, it does not create backpressure. The blades pressure effect causes the exhaust stream to compact itself along with gaining positive acceleration through the exhaust stream.
    I have a video that explains this further. In short temrs, it shortens the backstroke of the exhaust stream while increasing the forward stroke. This process called "exhaust scavenging" improves the volumetric efficiency of an engine. If you can move more exhaust out quicker while slowing the backsliding effect of an engine, you can improve volumetric efficiency. This is what the blade does.
    I figure I will knock out the backpressure argument while im sitting here. The blade creates a neutral pressure in the exhaust system without creating backpressure. To prove this, you only have to look at the california air resources board. Any product that is shown to create a backpressure in the exhaust stream MUST have a carb exemption. The product passed their test (i have .pdf of where it was tested) and does not require a carb exemption. It produced something like .2 psi. To fail the carb test a product must create 1psi or more of backpressure. Anything less then 1psi is considered to be negligible.
    It is for sale in california, and it did pass the carb regulations.
    On another note, if anyone would like to see the blade in action and you have a friend at a inspection station, here is what you do.
    CO2 output is directly related to engine output. If you put out more CO2, you are burning more energy. There is no getting around that fact. So, if you have a friend with some time and an inspection station, have him use the wand on your exhaust stream and measure your CO2 output. Then, install a blade and measure it again. Your CO2 output will go down. Therefore, you are expending less energy for the same amount of output as before. Its an easily measurable test that can be performed by anyone.
    On yet another note, why don't manufacturer's put this device on their cars if it is so awesome? Well for starters, it adds yet another filter element to your car which consumers will have to change. It also has to be changed relatively frequently depending on driving environment. Also, having numerous aquaintences on that side of the business, I have found that no matter how good any product is, you are looking at a 2 to 3 year planning and testing process before any product will hit the assembly line. So if someone comes out tommorow with something that adds 50% to your gas mileage, it still won't come out off the production line for 2 to 3 years.
    Send me a pm and ill give you my instant messenger handle and we can get this information uploaded to your ftp.
    Hopefully, I answered in a fair manner your questions.
  5. dogfriend
    7,512
    1,185
    Carmichael, CA
    Hi. Did you know that when you post, everyone who subscribes to the thread gets an email that contains a text copy of your initial post?
    I noted that you edited the statement above. It originally read:
    No financial interest?
  6. carguy_12
    33
    Thats why I edited it. Because I got so into the article I noticed I wrote that a few times. I used our as well towards the end. I was watching the videos as I was writing and made a mistake.
  7. dogfriend
    7,512
    1,185
    Carmichael, CA
    Oops. :madgrin:
  8. carguy_12
    33
    Well, i would like to point out, that I added in numerous paragraphs of text during my editing process as well. :p. Anyways, other questions?
    Ive also managed to cut down the flash drive to about 100mb as i got rid of all the videos other then the how it works.
  9. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    What's your cut on each one sold?
  10. carguy_12
    33
    I realize my previous edited* comments lend to the contrary of what I have said. But, I can assure you I am not an employee of sabertec nor have I ever sold a "blade" or have been paid. But, I would have to argue this to the end of time.
    I would rather stick to the arguments behind the product itself. Honestly, I just find this entertaining because I have seen so many "tornados, magnets, turbonators," and its just a energizing proposition to have seen a product that has the EPA certified testing to back it up.
    Like i said in my first post, I literally just searched the product on google and this is the top website with actual discussion on the matter. I wanted to lend my help having first hand experienced the "sales pitch" of the people at sabertech.
    So, moving forward. Any questions?
  11. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Is the testing of this device "double blind" testing?
  12. carguy_12
    33
    Its EPA certified testing at an EPA certified labratory. I have a pdf they gave me showing the labratory and the person who did the tests.
  13. butchbs1985
    225
    ChicagoLand
    2013 Prius v wagon
    Carguy_12, I have sent you the necessary FTP info. Let me know if you need further assistance!
  14. carguy_12
    33
    My upload rate to this site is just horrendous. I am adding files as I can, its just terribly slow at the moment.
  15. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    I'll take that as a no.
  16. butchbs1985
    225
    ChicagoLand
    2013 Prius v wagon
    Sorry. No cable access in my apartment so I had to settle for 6Mb DSL. At least we'll be able to see the stuff. Only two months before I get my own place!!! :D
  17. lenjack
    804
    114
    Pennsylvania USA
    If you're not an employee of the company, and you haven't been paid, does that mean you WILL be paid, either a cut or a flat fee? Do you sponser the Easter bunny tours? Sorry if this is cruel, and I'd be delighted to be proved wrong, but some of us are just too skeptical.
  18. carguy_12
    33
    I in no way, will be paid or benefited by giving you guys information about the product. lol. Its funny sitting at my end. Thats about all i can say. You guys think I'm wording my responses like a salesman, trying to confuse you. This is not the case. I am doing this out of my own perogative and that is all. If you said, hey carguy_12, i love this product. I want 200 of them now for my car fleet. I'd say, shucks, I cant help you *insert name here*
  19. carguy_12
    33
    Im not sure what a double blind test is to tell you the truth.
  20. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    A double blind test is where many of the real product and many "fakes" that looks the same as the real one, are all etched with individual secret codes. The person that knows the codes (for the real and fake ones) then puts this list in a safe and leaves. This individual is never allowed to come in contact with the testers till after the testing.
    The testers then test all the units (real and fake) and report the results of each unit by code number.
    A third party then takes the list in the safe and matches the results to the list with all the critics watching for no funny stuff.
    If the real product does have an effect (good or bad) then this shows up as a difference from the fake unit results.
    If this product is the real deal, then performing this type of test is essential. If it is a scam, then this testing shows it is snake oil. Note that all new drugs for human use must go though this type of testing, or better.
