Safe to drive with Red Triangle?
Discussion in 'Generation 1 Prius Discussion' started by Phee, Sep 8, 2019.
  1. Phee
    Phee New Member
    2003 Prius
    Ran out of gas. Red triangle. Added 5 gallons.Disconnected 12v battery cable. Triangle went out. 14 miles later, it's back on.
    Is it safe to drive 10 miles to mechanic of 25 to dealer or should I have it towed? Thanks
  2. Nelsonprius
    Nelsonprius Junior Member
    72
    Nelson, BC Canada
    2001 Prius
    I
    As far as I know if it starts it's safe to drive, it's not charging correctly but will run on gas, but others may know better
    51,937
    welcome!
    safe? only if you don't mind breaking down somewhere.
    you likely need a new hybrid battery, and there's no guessing how long it will last
  4. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    It's safe, go ahead and drive it to the shop.
    Bisco, what makes you think his HV battery is fubar?
