Safe to store 2012 Prius V for 3 months?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TheresaC, Jul 13, 2020.
  1. TheresaC
    TheresaC Junior Member
    Las Vegas
    Hello!
    I own a 2012 Prius v I bought in January 2019. Has been a great car so far. Has about 50,000 miles and I drove it cross country this past February.
    I live in Vegas and have since flown back to the small town I’m from to stay with my family until things gets a bit more under control. I would like to stay here for a few months. Would it be safe to let it set without driving for 3 months? My main concern is of course the hybrid battery. I filled up the gas tank, changed the oil, put air in the tires etc. I just read on one of the other posts about making sure the hybrid battery was at least at 6 bars. Unfortunately that’s the first time I saw that advice and I’m not sure how many bars it was at when I parked it at the storage unit.
    I really don’t feel comfortable flying right now so any help would be greatly appreciated.
    Thank you
  2. ASRDogman
    ASRDogman Senior Member
    8,057
    4,085
    You should be fine. The hybrid battery will stay charged a long time.
    The 12v battery will loose a lot of charge. When you get back, you should charge it before
    trying to start the car.
    You can get an AGM charger for around $30.00, and a volt meter for around $10-15.
  3. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    I wouldn't be concerned about the hybrid battery. I would have unhooked the 12 volt battery though. I new 12 volt battery with a fresh charge should be good for 3 months sitting idle, but if yours is 4 -5 years old it may have lost some capacity.
    TheresaC and Mendel Leisk like this.
  4. Leadfoot J. McCoalroller
    8,283
    7,794
    Pennsylvania
    2018 Prius c
    Agreed, hybrid battery won't discharge or degrade much at all, but the 12v will probably be dead when you get back to it.
    Show up with a charger, jump pack or AAA card when it is time to reactivate the car and you'll be fine- just know now that it won't be a quick pick-up.
    tvpierce and TheresaC like this.
  5. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Maybe you have a friend you've left the key with, or access to the key? Can have them put a battery maintainer on it for you, on top of the great advice already given...
    moto g(7) power ?
    TheresaC likes this.
  6. Mendel Leisk
    42,330
    Yeah, simple/effective tactic with the 12 volt battery, is disconnect the negative cable from the post. There will still be some drain on the battery over months, but MUCH less.
    A 10 mm wrench is all you need to do this. When reinstalling clamp, snug it down, then a little more firmly, but don't go nuts. Then pull gently on connection, ensure it's not loose.
    If you can't leave the hatch ajar and car unlocked, you will need to use the mechanic key (built into the fob) to get into the car on your return, and you will need to crawl through into the hatch area and release hatch with the emergency switch (behind pop out panel, just below threshold latch). Also, radio presets, trip meters, various similar memories, will be gone. Window auto-up may need to be relearned, but that's doable, and may not even be needed.
    Around 1:40 of first video here:
    Swapping in a Gen 4 Prius' 2ZR Engine into the Prius v | PriusChat
    by @Ragingfit , shows how to disconnect 12 volt battery cable.
    Addendum: reading closer, see you're across the country now. If it's no way practical to disconnect 12 volt now, just prepare for possible/likely problems on your return. Would be good to have a compact jump starter, and research replacement 12 batteries.
    #6 Mendel Leisk, Jul 14, 2020
    TheresaC and Ed Beaty like this.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    THIS. The hybrid battery will be fine......and if it is not, then the idle time had nothing to do with it's demise.
    When shopping for a small charger, it needs to be a smart, automatic, tender type.
    It does NOT need to specify use with an AGM battery.
  8. ASRDogman
    8,057
    4,085
    She's not going to be there. So it's going to site as it is now. Hopefully, in a garage so the city
    doesn't think it's abandoned.
    Actually ANY 12 volt source will will charge the battery. How many amps it is will determine how
    long it takes to charge it, also depending on the state of charge the battery has.
    Since it is an agm battery, or supposed to be, an agm charger is best. But according to Toyota,
    4 amps or less. Or 3.7 something???
  9. sam spade 2
    7,035
    2,804
    2017 Prius c
    But not "best" enough to worry about.
    Any good lead-acid charger will take an AGM to about 98% of it's absolute maximum charge and that is quite good enough.
    And some will do 100% without actually specifying that.
    2012 Prius v wagon 3 likes this.
  10. ASRDogman
    8,057
    4,085
    wwwhhaattteeverrrrrr
  11. TheresaC
    Las Vegas
    Oh what a relief thank you!
    ASRDogman likes this.
  12. TheresaC
    Las Vegas
    Oh what a relief. Thanks so much for your helpful replies! I have it stored safely at a covered storage unit. I was going to use the roadside assistance I have with my car insurance if the 12v needs charged or replaced.
    I’ll have to give some thought to charging it myself. Because it’s a hybrid I had been nervous about doing anything with the 12v battery myself.
    Thanks again! I am very relieved I don’t have to rush back to the city
  13. bisco
    52,826
    if roadside assistance doesn't jump start, get triple a before going back.
  14. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    It's printed on a label YUASA (sorry if spelling is off, not at home to read it). "...not too fast... not at a rate higher than 4.2 A".
    I've gotten it to weep electrolyte with a 4 A, but my battery is not 100%.
    moto g(7) power ?
    TheresaC and ASRDogman like this.
  15. ASRDogman
    8,057
    4,085
    You're welcome!
    Looks like you thought ahead! Good idea! :)
    If your insurance provides the jumping/charging, then you don't need to do anything.
    Hope your visit goes well!
  16. ASRDogman
    8,057
    4,085
    Please update us when you return as to how things went with starting your Prius.
  17. TheresaC
    Las Vegas
    Yes I will for sure. Hopefully I will report all went great! Thanks!
  18. TheresaC
    Las Vegas
    I am very happy to say after 3 months of sitting my Prius started right up! Oh how relieved I was. It did turn out that my key fob battery had gone dead. Spending days fretting about every possible thing that could go wrong I looked at a YouTube video on how to start vehicle with a dead key fob. I held it up to the start button to start and used replacement batteries I had bought before my flight. I am now safely social distancing camping in the mountains with my beloved Prius.
  19. bisco
    52,826
    july, august, september (n)
