Safest car jack capacity?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by berderder, Aug 14, 2020.
  1. Mendel Leisk
    42,277
    I've got no problems with the rear jacking point. I use the regular, somewhat cupped cradle, with a wood piece (2x4x4) in the cradle, and a hockey puck atop.
    Chock both front wheels fore and aft, nothing's going anywhere. The jacking point may be a little off-centre, but seems to work fine.
    Georgina Rudkus likes this.
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,562
    2,599
    Taylors, SC
    I prefer not to use the axle, since if it is bent, it might change the rear wheel alignment. The rear jacking point is not centered, but enough centered to allow both rear tires to clear the pavement. rear jacked up off ground.JPG
  3. ASRDogman
    ASRDogman Senior Member
    8,048
    4,079
    IF you bend that rear axel by jacking up the car, you have a serious problem!
    If you're doing a transmission fluid change, and the car is tilted, you can't fill it correctly.
  4. Georgina Rudkus
    3,562
    2,599
    Taylors, SC
    The safer alternative would be to jack up under the rear spring seat and rear shock attachment point.
  5. ASRDogman
    8,048
    4,079
    No difference in safety by jacking in the middle.
    Then you can put the jack stands on the axel.
    "IF" that axel was so weak that it would bend if you jacked the car up by it, it would have bent
    While you drove it.
  6. Mendel Leisk
    42,277
    I'm gonna stay out of this.
  7. berderder
    berderder Junior Member
    69
    Connecticut
    See photo attached
    Are you saying my particular jack is too small to bite onto the outcropping of the rear jack point?
  8. Georgina Rudkus
    3,562
    2,599
    Taylors, SC
    Yes, you need a flat top adapter plate. A 2-1/2 inch riser will probably be needed to get both rear tires off the pavement when the jack reaches it's full height.
    berderder likes this.
  9. berderder
    69
    Connecticut
    It seems like it would just be easier to return this jack and buy one with better height and a large flat jack surface.
    Are those commonly sold items, the riser and adapters? I can’t find anything online...
  10. Georgina Rudkus
    3,562
    2,599
    Taylors, SC
    They are custom made items. We are making a few but cannot sell them here.
    A newer version of he flat top aluminum low profile racing jack that you see in my attached photos is often sold for $60 with widely available coupons. The original shown sold for $100 nearly 15 years, ago.
    1.5 Ton Aluminum Rapid Pump® Racing Floor Jack
    #50 Georgina Rudkus, Aug 19, 2020
  11. berderder
    69
    Connecticut
    Thanks! I think I will try that one, looks good
  12. Georgina Rudkus
    3,562
    2,599
    Taylors, SC
    You're welcome.
    Using a pinch weld adapter like the one shown, you can jack up the front enough to get both the front and rear tire on one side above the pavement. This is ideal for rotating tires. I would, however not recommend getting under the car supported by the jack only. front pinch weld jacked.JPG both side tires off ground.JPG
  13. Georgina Rudkus
    3,562
    2,599
    Taylors, SC
    Then, if you need to move the front tires from the right to the left as recommended in the pattern shown, you can use it to jack up both front tires to do just that. EDUtire-rotation_all-patterns_960x220.png front jacked up.JPG
  14. Mendel Leisk
    42,277
    I picked up this flat rubber cradle to occasionally sub for the conventional cradle on my jack:
    Floor Jack Saddle | Princess Auto
    All the cradles are pin in socket, and I think the diameter is pretty consistent. Verify before you buy.
    One thing I found with the above link, it had a weld bead around the base of the pin, that prevented it seating properly. I made a washer out of 3/4" medite that accommodated the weld, still allowed the pin to lock.
    berderder and Georgina Rudkus like this.
  15. berderder
    69
    Connecticut
    I thought I heard you shouldn’t lift an entire left or right side with a jack? Maybe that’s just my imagination...
    Ah ok, maybe what I need to google is “saddle” to find these. I initially couldn’t find anything..
  16. Georgina Rudkus
    3,562
    2,599
    Taylors, SC
    It won't hurt to raise one side as long as the lift is stable and you don't get in the car or load or unload it. The chassis is stiff enough to take it, if all you are ging to do is to change and rotate tires.
