Safety Connect for 2017 Prius Prime Advanced
Discussion in 'Prime Main Forum (2017-2022)' started by shebobg, Jun 13, 2022.
  1. shebobg
    shebobg Junior Member
    46
    Woolwich Township, NJ
    I have a 2017 Prius Prime Advanced. I read that as of November 1, 2022, the Safety Connect SOS button will no longer work. Is there a fix for it or do I have to go without?
  2. schja01
    schja01 One of very few in Chicagoland
    1,754
    1,168
    Chicagoland
    2018 Prius
    You do have an active subscription don’t you.
  3. shebobg
    46
    Yes I do but don't know if I should renew if it will no longer work at the end of the year.
  4. schja01
    1,754
    1,168
    Chicagoland
    2018 Prius
    I have a 2018 Advanced and I’m paid up until late 2024. I just checked and it still had the green LED but I didn’t press the button. At the request of support I did test it a few weeks ago and it worked then. FWIW.
  5. schja01
    1,754
    1,168
    Chicagoland
    2018 Prius
  6. shebobg
    46
    I pay annually though so it would be coming up for renewal by then.
  7. Salamander_King
    Salamander_King Senior Member
    10,975
    8,873
    New England
    The deadline is only for vesicles using 3G telematics for the Safety Connect. PP has 4G LTE. Your car is not affected by the shut down.
  8. CharlesH
    2,787
    1,152
    Roseville, CA
    Yes, some folks tracked down the part number for the 2017 Prime Safety Connect module, and verified that it is 4G/LTE and thus not subject to the loss of service with the shutdown of the 3G network. No such luck for the 2012-2015 Prius Plug-In (PiP), which has 3G Safety Connect hardware.
    Salamander_King likes this.
