Safety Recall J0V - Where is the Remedy?
Discussion in 'Gen 3 Prius Main Forum' started by JackTheNarrator, Nov 20, 2018.
  1. BLS2020
    BLS2020 New Member
    L.A.
    It is the original battery. I have not done anything to the car other than oil/coolant/ tires change. I still have original brakes on the car too. Car has been very good to me just sad to see all these faults on the model. I do burn a lot of oil though, told the dealer but they just said it was normal...
  2. Mendel Leisk
    41,434
    I wouldn't hesitate to change it; it's had a good run. You could assess it's condition (something like Solar BA5), and/or try a charging session. Or at the least measure it's at-rest voltage with a digital mulimeter. But 8 years old, hardly worth it.
    Not really, the 12 volt battery is just one of the "consumables"; you can't fault it after this long.
    Bay Stater likes this.
  3. scona
    scona Active Member
    225
    207
    Courtenay, BC, Canada
    2013 Prius v wagon
    Has anyone had this done? I have no idea what software version my 2012 is on and figured this may be a good thing to do. Wanted to know if anyone had done it and had any negatives or positives to report.
    Completed software update for Safety Recall R66 this a.m. Took about an hour to do and there is no noticeable difference in operation. It is 25f here this morning, performance might differ with higher temperatures, will report if so.
    Bay Stater and Mendel Leisk like this.
  4. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    I just had it done yesterday. I didn't receive a Toyota notice that the fix was available but when I took my Prius in for it's 6 month checkup yesterday they said that they had the software so I had it done.
    So far I have not seen any negative effects.
    Bay Stater and Raytheeagle like this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    I had mine done yesterday up here:).
    Put over 60 miles on our Prius since and no noticeable change;).
    But it took 2 hours as the “master tech” didn’t grace the dealership with his presence until 8 am:rolleyes:.
    But I got the notice to schedule an appointment, as I avoid the dealerships at all costs(y).
    Bay Stater, lumpy95 and Grit like this.
  6. Mendel Leisk
    41,434
    8 am's pretty early? (n)
  7. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    They start appointments at 7 am;).
    So I had to walk the lot and stare at large urban assault vehicles and pick em up trucks:cool:.
    Amazing how much one of those costs these days(y).
  8. Braddles.au
    Braddles.au DEFAnitely using an EBH
    295
    99
    Canberra, Australia
    Toyota Australia's reference number for this recall is JGG76. First mentioned 5 October 2018, the appointment notices are arriving now.
    Toyota Australia estimates 1 hour (not 45 minutes) and there is no mention of the possibility that the inverter may need work.
  9. ChapmanF
    18,165
    Had mine done this morning. Checked my HV Control calibration IDs in Techstream beforehand, top one was 896B34701800, as expected for a "2010 Prius #2" with E0E done but not J0V. Checked after the job and it's now 896B34732000 as it should be after this recall.
    Car only turns left now, so I have to make rights by going around the block, but nothing else seems to have changed.
  10. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    Just do it in reverse and you’ll be fine. LoL
    m.wynn likes this.
  11. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Check your 12v bat.
    m.wynn likes this.
  12. ChapmanF
    18,165
    It also only turns left. Pretty much stays with the car.
    m.wynn and Threej like this.
  13. Threej
    Threej Member
    99
    99
    Portland, OR
    Huh. I also noticed my Prius was starting to drift more and more to the left. My solution was to cut off the CNN.
  14. FnRedPrius
    FnRedPrius Active Member
    100
    121
    Pilot, NC
    I kept getting turn by turn directions so I turned off the radio and it continued. Then I turned off the cell phone and it continued. Strange thing is it only happens when SWMBO is in the car.
  15. ChapmanF
    18,165
    But with the central noetic nexus turned off, the car's right ECU won't know what the left one is doing.
    Threej likes this.
  16. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Got the official Toyota safety recall letter JOV the other day. Had the FW reflash done today. So far no noticable differences yet. :whistle:
    m.wynn, jerrymildred and Raytheeagle like this.
  17. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    I got the letter last week and had this done today. So far I don’t notice any difference in terms of drivability or performance.
    As an aside, one of the dealers didn’t even call me back when I called their service department to make an appointment to have this done. I guess they didn’t want to do it or something. Another of my local dealers had no problem welcoming me in for the recall service. Took about two hours.
    Also in California we don’t really have a choice whether or not to do the recall because the DMV can refuse to renew your registration if you can’t prove that you’ve done the recall. I think the dealership may even report that you’ve done it to the DMV.
    #57 mediahound, Mar 29, 2019
  18. hill
    8,803
    Many safety recalls take forever because either room is scarce at the service center or parts (un)availability .... they don't stock inventory due to costs.
  19. ChapmanF
    18,165
    The ones that are firmware updates have to be kept on a special shelf where the bits won't roll off.
    GG707 and jerrymildred like this.
  20. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I use a barrel shifter to keep my bits from rolling off.
