Safety Recall Rear Doors
Discussion in 'Gen 5 Prius Main Forum' started by exbauer, Apr 17, 2024.
  1. bisco
    52,891
    i'm not concerned about current owners, but it's quite a hit on production
  2. Hammersmith
    Hammersmith Senior Member
    2,497
    2,562
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Oh, forgot to mention that I don't know if they're rolling out the recall in phases, or if we're all getting access to the fix at the same time. The dealer letter doesn't say anything about phases, so I suspect it's going to be all at the same time. My VIN is under 3000(built 30 March, 2023), so I suspect I'll be in one of the first phases if they do it that way.
    #162 Hammersmith, Aug 28, 2024
  3. Hammersmith
    2,497
    2,562
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Production restarted back in mid-June, so it was a 2 month loss. So 2024 production will be down maybe 10k-15k below what it should have been. (I'm going from old memory on monthly production figures, so take those with a HUGE grain of salt.)
  4. KMO
    KMO Senior Member
    2,031
    751
    Finland
    2023 Prius Prime
    Looks like a copy-and-paste error in step VI.3.h - nonsensically repeating "Using a moulding remover, disengage the 3 claws to remove the rear door trim upper cover." from a couple of pages previously. Not sure if there should have been another step about the yellow clip there.
  5. Hammersmith
    2,497
    2,562
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Did you post the European instructions before? Maybe we can cross check the two.
  6. KMO
    KMO Senior Member
    2,031
    751
    Finland
    2023 Prius Prime
    No, I haven't found the European version of the instructions. Got what seemed to be the document number, but couldn't find the actual document.
    (But my dealer apparently could - my car was done a few weeks back. Took one-and-a-half hours.)
  7. Hammersmith
    2,497
    2,562
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The kit comes with two new yellow clips, so the wrong instruction should say something about removing the existing yellow clip by sliding it out.
    KMO likes this.
  8. Hammersmith
    2,497
    2,562
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The recall is now fully live. I just got off the phone with my dealership and I'm scheduled for next week.
    stuyguy and Julio_E like this.
  9. Hotdog453
    Hotdog453 Junior Member
    Ohio
    2024 Prius Prime
    XSE Premium
    I take full credit for making it come out, given I took the effort to drive several states over to get a different car last week, since I got tired of waiting.
    You're welcome.
    :p
  10. NullDev
    NullDev Member
    121
    63
    Ohio
    2024 Prius Prime
    XSE
    Is there some way I can get you to buy a snowblower so it won't snow so much this winter?
    Hotdog453 likes this.
  11. Tom Mulloy
    Tom Mulloy Junior Member
    Oshkosh, WI
    2024 Prius Prime
    XSE Premium
    My XSE Premium arrived at the dealer a couple days ago. I was supposed to take delivery on Friday, but another "issue" popped up. The service department told my sales guy that there is a "stop sale" (not sure of the exact term) in addition to the one for the rear door recall. Service said they can't deliver a car that was only shipped with one remote. The second remote is supposed to arrived on Tuesday. Anyone else heard of this?
  12. Julio_E
    Julio_E Junior Member
    38
    Michigan
    2024 Prius Prime
    XSE Premium
    Maybe it's related to this: Delivered with one key FOB | Page 6 | PriusChat
  13. Hammersmith
    2,497
    2,562
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    That sounds like bs. The only stop sale is for the rear door recall, and hundreds of thousands of Toyotas have been delivered with only one remote over the last couple years.
    At a guess, I wonder if they had a lot of techs take Friday off to make it an extra long weekend, and they weren't able to get the pre-delivery inspection/prep done in time.
    There are two active recalls on the Prius/Prius Prime:
    1. Safety Recall for the rear doors (if yours was built after April, it already has the updated part)
    2. Compliance Recall for the max weight stickers(but this is only for cars from Gulf States Toyota - a WI car shouldn't be affected)
    There is one other service campaign - the 2nd key delivery campaign - but your car(if built in April or later) should not be eligible for the new key until October.
    There is one Prius Prime-specific TSB for the 2024 model year(T-SB-0054-24), but I doubt that applies to yours as I think yours already has the updated programming(it's an ECU update to make sure the car properly goes into sleep mode while being plugged in for charging).
    Now if your car was a late March or April build that got held up at the port until the fix was ready(or it's been at the dealership since April), then I could see why they'd want to keep it. It probably qualifies for the 2nd key, and it might need the ECU update.
  14. Hotdog453
    Ohio
    2024 Prius Prime
    XSE Premium
    FWIW, I picked mine up last week, and this did not occur. The dealer explained the 'one key fob issue', promised Toyota would reach out etc etc, but it was never hinted to be delayed.
  15. Mike Ireland
    Mike Ireland Junior Member
    2024 Prius Prime
    XSE
    We live in Nanaimo, BC, Canada and are the proud owners of a 2024 Prius Prime XSE (purchased mid-April), which we love. After reading in the forum to check the app, I did. Found out that both our second key fob and the rear door switches were available so I went to the dealer today and now have an appointment for next week to program the fob and install the door switches. If you haven't already, check your app under the Health tab for your car's status.
  16. Tom Mulloy
    Oshkosh, WI
    2024 Prius Prime
    XSE Premium
    9/3/24 UPDATE: Picked up the car today, with only one remote. Apparently an over-zealous service advisors blocked last Friday's delivery. As another poster indicated, there is no stop sale on a 1 remote delivery. Just received a "how'd we do" text inviting me to take a survey. Stand by.
  17. Gokhan
    Gokhan Senior Member
    6,715
    2,672
    Paramount CA
    Safety recall: long over.
    Many dozens of Priuses and Prius Primes are currently in stock in Southern California, available for immediate purchase at MSRP, albeit no LE and SE trims, which are apparently the most popular but least produced. In fact, there are about four dozen XSE Premiums sitting in dealer lots with many more dozens in transit or production.
    It looks like we have finally reached the point that you could walk into a dealer and buy a Prius/Prius Prime at MSRP.
    Next: Dealer discounts below MSRP arriving shortly.
    Availability of the new Camry, falling gas prices, slowing down economy, and falling Toyota sales are helping find a Prius/Prius Prime now.
  18. Hammersmith
    2,497
    2,562
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I'm currently at the dealer getting my rear doors done. They're also updating the firmware on my DCM and installing the TRD Performance Damper(the car has to be on a 4 post lift when torquing the hardware, so I couldn't do it myself).
    Have been here for 5.25 hours so far. lol
    (includes 1hr lunch break for the tech)
    But this dealership has fresh baked cookies every hour or so, there's that. ;)
  19. Gokhan
    6,715
    2,672
    Paramount CA
    I saw a white SE and a gray XSE (Premium?) parked next to each other looking for owners at West Coast Toyota of Long Beach today.
    I should say the gray looked better than the white when viewed side by side. It has more shine and luxurious appeal into it.
    I like the aero wheel covers on the LE/SE better than the 19" wheels on the higher trims.
  20. 2023p
    2023p Active Member
    165
    107
    Here
    2023 Prius
    Being told by dealer (USA) they need two appoints for the rear door recall. One ton"inspect" and one to install if needed. Separate days, they will not order parts until they "know it needs it" ...
    Is that normal? Would like to avoid 2 separate visits on differents days.
