Sagging HEATSHIELD: Significantly diminished effectiveness?
Discussion in 'Prius c Technical Discussion' started by davide, May 23, 2018.
  1. davide
    davide Junior Member
    86
    suburban Detroit
    I bought the custom-fit front HEATSHIELD from the affiliated Shop soon after I bought my 2012 Prius c. It seems that the center V area (just past the rear-view mirror) sags down now---it's exactly 4" away from the windshield at the center-top of the V---more than it did when it was new (perhaps because I always store it during the summer by folding it once & placing it behind the passenger seat, making a permanent crease).
    Question: Does this distance from the windshield surface significantly diminish its ability to reflect the sun's heat? Should I consider replacing it with a new one? :(
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    I am trying to picture what you're describing and for the life of me I cannot do it. Can you take a picture of what it looks like?
    Edit... I get it now. Sorry, lack of sleep.
    I imagine any gap will allow the heat in. Maybe attach a suction cup to it so that it stays on the windshield?
  3. GregoryG
    GregoryG Junior Member
    Forest Grove, OR
    I don't think a sag in the middle will make much difference. The only thing between the window and the heat shield will be a small amount of air, and that small amount of air won't be able to hold a whole lot of heat. The heat shield will still be reflecting the majority of sunlight back outside of the car.
  4. orenji
    orenji Senior Member
    5,887
    3,490
    No difference at all.
