San Diego area, help for young Prius driver
Discussion in 'Gen 2 Prius Main Forum' started by Chris HV, May 18, 2018.
  1. MilkyWay
    MilkyWay Active Member
    823
    359
    23
    MI
    I've already guided you on how to repair her car for $80 to $180. Not sure why you are being paranoid and asking around for shops it is so easy a blind person can do it.
    The part, at that exact dealership, and every Toyota dealer in the country is approximately $80. It should already be in her possession.
    The labor, if you have a friend, is so incredibly easy (5-10 minutes to remove, 5-10 minutes to put back on) that they will do it for FREE...Or buy them lunch...Or give them $5!!!! That easy and quick...Pull into a gas station that services cars...an oil change shop....anyone can do it. A gas station mechanic or oil change shop mechanic will probably do it for $50. An independent mechanic shop no more than $100 labor (this assumes she pulls into shop...pops hood, and points at the part and says how much to change this part).
    There will be no coolant spills....and these cars last to 500K miles there is zero point in changing the coolant right now. It is preventative maintenance that is pretty much pouring money down the drain as you aren't going to prevent anything because they aren't known to have problems from not changing the coolant.
    #41 MilkyWay, May 22, 2018
    Montgomery likes this.
  2. JC91006
    16,936
    8,647
    Why wouldn't the coolant come out when you remove the hoses from the valve?
  3. Chris HV
    Chris HV Member
    67
    36
    East Coast, USA
    2018 Prius Prime
    I appreciate the time you spent trying to help, I really do!
    But I will say this. If you had read my OP you would know that help is not sought for ME (in which case you did offer some interesting and helpful tips which are duly-noted!) but for my daughter who is a young, gullible young person living 2.500 miles away. I'm not sure if you are a parent, if you are, I simply do not understand how you could say some of the things you said...
    BTW, you are 100% wrong about some of the things you state above. For example, some stealerships charge up to $235 for that 3-way valve.
    Another example: where I live the only honest shop (Mennonite-owned, good people) almost NEVER sees a Prius outside of my cars. Unfortunately, the only times they see them is when I need a state inspection (used car just bought) because these awesome cars are so damn-reliable, and I do all the maintenance myself. What does this mean in practical terms? As opposed to a "hybrid shop", they have no clue as to how to do ANY kind of repair. Therefore what they would systematically do, as the owner told me himself, is go to their shop software and follow the instructions... This means BTW charging the "recommended" labor time which is usually the same as the stealership (but at a lower rate which may help a bit.)
    I disagree with you about ignoring the coolant replacement for a 160K car that I now know probably never had it. I think you would be shocked if you could drain the fluid and examine it with a fair mind... (or drink it, as you seem to do since you claim it's so DELICIOUS.) I also know from personal experience that bleeding the system from all remaining air bubbles is pretty tricky on the Prius (did it a few years back on our 2004) and definitely NOT something I would have done by some hooniak mechanic at any oil change shop. Geez, let me see, what could possibly go wrong...
    Anyhow, I do thank you again.
    Chris (PARANOID PARENT... LOL)
    Raytheeagle and MilkyWay like this.
  4. Chris HV
    Chris HV Member
    67
    36
    East Coast, USA
    2018 Prius Prime
    Presumably because they pinch the crap out of the hoses, preventing most loss.
    Now... is that a good idea on a 160K car? I'm not so sure.
  5. MilkyWay
    823
    359
    23
    MI
    I definitely would not recommend changing coolant at oil change shop. For that I would advise spending the $150 or whatever they charge at stealership. They have the equipment and the correct coolant.
    I would be very comfortable with a partially blind mechanic at a gas station for the coolant control valve (just saying it is a simple 30 minute or less job)...And then take to Toyota to flush and bleed system.
    I have a very wild 3 year old so won't be behind the wheel until the 2030s!
  6. Chris HV
    Chris HV Member
    67
    36
    East Coast, USA
    2018 Prius Prime
    FYI stealership charges $496 (+tax, shop fees, etc.)
    For your kid you're good to go, by 2030 for a mere $3,500 a year the car will drive itself and take itself to the stealership when a code pops up...
  7. JC91006
    16,936
    8,647
    What were the other repairs the stealership recommended?
    Many times when there is a bad 3 way valve, they will also find coolant leaking from the engine water pump. I'm wondering if that was one of their recommendations to change out.
  8. Chris HV
    Chris HV Member
    67
    36
    East Coast, USA
    2018 Prius Prime
    Just for reference, today I went to the local stealership (Western Maryland) to make a recall appointment for my wife's Prius and the sign said "Diagnostic fee is $52 to $112."
  9. JC91006
    16,936
    8,647
    Here in California, the hybrid diagnostic charge is around $120-$140. They hose you when you own a hybrid
    edthefox5 likes this.
  10. Chris HV
    Chris HV Member
    67
    36
    East Coast, USA
    2018 Prius Prime
    I don't have the quote in front of me but I do know there are no leaks. I seem to remember massive dollar amounts for some grease leaks on ball joints and stabilizer bar and a cracked drive belt.
  11. JC91006
    16,936
    8,647
    The leaks on ball joints and stabilizer bar sounds like an axle seal leak on the driver's side. That's the only common leak from this generation Prius. Never really heard of grease leaks on ball joints etc.
    The cracked drive belt is $15 to replace. But I'm sure they quoted a crazy price for this too.
    I don't think your daughter's car has anything urgent that needs immediate care. Take your time in finding a fair mechanic that can do the work, there's no rush as her car won't be breaking down while she's driving.
    Raytheeagle likes this.
  12. toyopri808
    toyopri808 Active Member
    226
    116
    I recommended the out-of-warranty hybrid specializing shop on Miramar Road (which is 6 miles from KM Toyota)..
  13. Chris HV
    Chris HV Member
    67
    36
    East Coast, USA
    2018 Prius Prime
    Hi JC, I do agree about the lack of urgency!
    I did find the Kearney Mesa Toyota quote, here are the details (as best as I can decipher their jargon):
    1) P1121 flow valve stuck: $497.60
    2) drive belt, heavy crack: $173.32
    3) front brakes and rotors: $572.40
    4) license plate bulb: $43.78
    5) Right front lower ball joint leaking grease, left side seeping: $331.12
    6) Both side stabilizer bar links seeping grease: $542.86
    7) 4 wheels alignment: $133.49
  14. JC91006
    16,936
    8,647
    $2300. Holy cow. And you have the HV battery replacement in the future. Did they try to sell your daughter a car while she was there? Cause those quotes would scare the crap out of me and I would want to just ditch the car.
    Predatory pricing at it's finest. Going in for a "check engine" valve issue and get recommendations for multiple other issues. I guess they have to justify the "diagnostic" fee.
    I would get second opinions on those repairs
  15. Chris HV
    Chris HV Member
    67
    36
    East Coast, USA
    2018 Prius Prime
    How did you know LOL? Yup, my daughter said that there was a "very nice young man" who told her she would get one whole thousand dollars if she would trade this (otherwise pristine... I know, I used to own it) 2008 Prius is she would simply buy a 2018...
    She apparently took it to another shop on the recommendation of a friend who maintains her car there. They don't do many hybrids so I won't recommend she goes there for maintenance but apparently when she handed the KM Toyota estimate to the mechanic, after looking at the car he went down the list and went: nope, nope, nope...etc. while shaking his head.
    Meanwhile, I just realized that these a$$holes at Kearney Mesa Toyota actually entered their obscene list as a "repair" which of course will end up on the Carfax. I am FUMING....
  16. JC91006
    16,936
    8,647
    If she has already gotten a second opinion and they don't feel much of anything is needed at this time, you should just keep driving the car until you find a mechanic that will do that valve repair. It's pretty straight forward, will take about 1 to 1.5 hours to complete if you're rushing.
    If you're bringing the car to a mechanic to fix, it's probably not a good idea to supply them with parts. They would never guarantee the repair that way. Just have them do it (my guess $300) and be done with it. Without this repair being done, your daughter will not be able to pass a smog check when it's time to register the car. If the belt is really worn, you should get that replaced too.
    I would still double check to make sure the brakes are sound (it's a safety thing).
  17. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    Sent him my recommendations via pm. He should be set now hopefully. Stealerships are generally in the business of making money off repairs so they do this sort of thing. Nothing new, or unexpected.
    Raytheeagle and Prodigyplace like this.
  18. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    It’s part of the wallet flush procedure ;).
    MilkyWay and JC91006 like this.
  19. Prodigyplace
    12,713
    11,848
    Central Virginia
    They forgot to change the blinker fluid! :D
    sfv41901 and Raytheeagle like this.
  20. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Classic dealer rumping.
    The only thing in the dealer list that got my attention was cracked drive belt. That’s the one that will bingo the car. The belts only job is to turn the engine water pump. Belt falls off pump stops turning no temp gauge
    To show engine over heat car is driven till check engine light comes on.
    Too late damaged head from over heat. Seen lots of those on this site.
    If I was her father I would instruct her to get that belt changed now. It’s probably the original belt.
    Meg&Bear likes this.
