Sanity Check Prius vs. Accord 4dr EX '13
Discussion in 'Gen 3 Prius Main Forum' started by cycledrum, Mar 26, 2013.
  1. TwoUnderPar
    TwoUnderPar Member
    78
    72
    Raced NASCAR circle track for 12 years. No way you're going to thrive in that environment unless you learn to brake left, gas right. Sometimes clutch, brake, gas all within fractions of a second. Learn to brake with left foot. I know we are not racing in the Prius but a right foot only approach to braking and gassing is incredibly less efficient/less reactive than using both feet.
  2. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Aha, I see this is up at Sears Point / Infineon Raceway. Did couple trackdays there. Tricky track that is.
    I applaud your racing career, and you are right, two foot driving is good in racing. There's a lot of parallel in that to sportbike (motorcycle) canyon carving / racing.
    I always rode with index and middle finger covering / applying the front brake which you know is on the right grip as is the twist throttle. There is trail braking into turns, also keeping throttle on to keep tension in the drive train in turns, and so forth.
    I say fine to use left foot to brake in car at times. But, if the car starts spinning out of control and one is using the left foot to brake, I don't know how someone will brace themselves to control the brake and there's a high possibility of hitting the gas too.
    I used to left foot brake up til 3 1/2 years ago then kicked the (bad for street) habit.
    Left foot or right foot? | The Safe Driver
    More good reasons why not to left foot brake.
    Driving with right foot on brake and gas pedal? - Yahoo! Answers
  3. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Went to Piercey Toyota this evening, took a sit in a 2013 Prius Four with power softex driver's seat. It wasn't all that, just ok.
  4. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Nothing to block glare from sun on Prius navigation screen -
    Accord dash has a hood over nav screen to block the sun
    Camry has nothing block the sun. What would it take for Toyota to think of these details?
  5. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Toyota cannot even design door armrest that is high enough and not a brick.
  6. doug jordan
    doug jordan Bigbambo
    Berlin heights Ohio
    Maybe Toyota had to cut some things in design to keep the price down? Ya know, put the yen into reliable parts that keep it running. I'm sure toyota is advanced enough to meet every "nancy's" needs and charge more for it. I had a ferd f250 that had great leather seats, great factory sound system and a terrific heater but EVERYTHING rusted off and I sure made it rain(like people do at a strip club) at the dealership to keep it running. My 2011 tundra.....not one issue! cycle....buy an Audi, you will love it!
    P.S. I too can't wait to drive my prius!
  7. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    ok, so you or someone tell me how to attach a foam pad to a fabric door armrest without damaging the fabric after years. Double sided duct tape transfered onto the fabric.
  8. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
  9. doug jordan
    Berlin heights Ohio
    Geez, I must have bigger fish to fry in my life than to worry sooooo much about my armrest! I know you'll find it hard to believe, but actually drove a VW for years and my arms just dangled right there by my side. Bassards!
  10. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Well it is titled "Sanity Check".
    doug jordan likes this.
  11. PLSPUSH
    PLSPUSH Active Member
    359
    132
    Tulsa, Okla.
    @6'4 the armrest is too low for me also, but @5 ft tall it's too high for my wife!!!!!!!!
  12. Armyguy03
    Armyguy03 Junior Member
    This thread is very amusing.
    PLSPUSH and TwoUnderPar like this.
  13. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Can you secure some non-slip rug mat to the underside of the pad? It might at least keep the armrest in place while there's pressure on it.
  14. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I picked up some stuff from a craft store that's like putty. Seems to hold it in place and it's easy to pull it off. We'll see how it holds up over time.
  15. bisco
    51,950
    you might be failing.:eek:
  16. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    They put in telescopic steering wheel, all 1/2 inch of it.
  17. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Well, I suppose I can get used to not using the door armrest, I've tried that a bit. It's a little weird cause I've used it in probably every other car I've had, old habit. Who knows, maybe keeping my elbow off the armrest will save my elbow from getting taken out if the seat airbag ever went off in a crash.
    As for the steering wheel not telescoping close enough, there is 17" between the center of steering wheel and my chest and the police reports say there ought to be 10" to 12" minimum. I'm not sure the steering wheel airbag would be all that effective being that far away.
  18. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    quote="cycledrum, post: 1769669, member: 39169"]This joke of a dead pedal looks for size 6 shoes, not my US size 12. I see, wear out the carpet above pad, then wet shoes will deposit water to rust out the floorboard. Awesome.
    Dry your feet and wear Depends during those long drives and you'll eliminate that wet spot under your shoe.
    PLSPUSH likes this.
  19. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    hmmm, how to respond...
    a) That's real funny except it took you three days to think it up, smartypants.
    or b) I don't like snide comments any more than you would, so you can keep them amongst yourself if you don't mind. k, thx.
    :p
  20. doug jordan
    Berlin heights Ohio
    Seriously, it is hard for me to understand or validate the high level of bitterness with toyota's shortcomings on the prius? Is the something more that your not posting? I'm close with Ferd motar company because they sold me flat out junk in that, it didn't drive most of the time. For this, I will never buy another!
    Lighten up if you can and realize that we live easier now than most royalty in past history!
    PLSPUSH likes this.
