SARS-CoV-2 Coronavirus (COVID-19)
Discussion in 'Environmental Discussion' started by tochatihu, Jan 26, 2020.
  1. Trollbait
    12,822
    Or false negatives from the test.
  2. Prodigyplace
    12,712
    11,848
    Central Virginia
  3. tochatihu
    tochatihu Senior Member
    9,975
    3,847
    Kunming Yunnan China
    2001 Prius
    Face mask leaks
    Prodigyplace likes this.
  4. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Nothing that a little more duct tape can't solve :whistle:
  5. bwilson4web
    16,530
    or superglue.
  6. bisco
    52,832
    looks like my rear bumper
    Raytheeagle likes this.
  7. tochatihu
    9,975
    3,847
    2001 Prius
    I absolutely do not want to talk about your rear bumper.
    mjoo likes this.
  8. bisco
    52,832
    i promise not to post a pic
  9. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    You posted it once;).
    Why not again:whistle:?
    I bet some of your finest handy work(y).
  10. tochatihu
    9,975
    3,847
    2001 Prius
    Switzerland has been identified as past peak of new daily cases by Gompertz model
    COVID-19 Regional Numbers of Infected People
    This does not mean 'it's over' it means that new daily case counts are expected to decrease. Tat model further predicts final total cases will be >35 thousand. With < 9 million Swiss that is a high incidence.
    Hubei Province of China was early and fast. It has <68 thousand cases and population of 59 million. That is lower incidence.
    Italy will be past peak soon we hope.
    S. Korea, Luxembourg, Norway and Brazil already are and others may be, at elm.nsupdate
  11. bisco
    52,832
    dr. dfauci says, 'i'd bet the ranch that people who have had it will be immune'
  12. tochatihu
    9,975
    3,847
    2001 Prius
    On that note,
    Coronavirus Dashboard
    lists number of recovered. There are now more such people outside China than within.
  13. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    A Swiss Doctor on Covid-19 &#8211; Swiss Propaganda Research
    A few excerpts from the Swiss post:
    Everybody take a deep breath.
  14. tochatihu
    9,975
    3,847
    2001 Prius
    link @1173 mentions Sweden as having less restrictive policies (isolation only of elders and symptomatics). As that country is (Gompertz) scheduled to peak very soon, it may yield interesting comparisons with others with more restrictive policies.
    bwilson4web likes this.
  15. fuzzy1
    10,705
    So far, San Marino has lost 0.065% of its entire population to this outbreak. Small population though.
    Italy, 0.0166%.
  16. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    We're beginning to get a better glimpse at the magnitude of asymptomatic +SARS-CoV-2 cases.
    Statistically significant data has been very limited to this point, but now a picture is starting to emerge via Iceland. Iceland has a population of ~360,000 and has been testing >25,000 tests per million (highest proportion in the world).
    Iceland is now sampling asymptomatic people in Reykjavik (does not count mild cold symptoms). 0.84% of these tests have come back positive (52 of 6163) - see link below. That compares to 0.25% of the population who have tested positive.
    We will need to repeat this study in other countries, but this lends further support to the "tip of the iceberg" theory that a very large percent of +SARS-CoV-2 go uncounted almost everywhere. Many implications follow from this.
    Google translated from Norwegian:
    Google Translate
    bwilson4web and mjoo like this.
  17. bwilson4web
    16,530
    I'm not fond of percentages and found this in the article:
    Since deCODE began testing on March 13, 6,163 Icelanders without coronary symptoms have been studied.
    52 of the samples were found to be positive for Covid-19.
  18. bisco
    52,832
    dr. fauci tells cnn's jake tapper, 'i expect millions of cases in the u.s., and between 100,000 and 200,000 deaths based on models, but don't hold me to it'.
  19. tochatihu
    9,975
    3,847
    2001 Prius
    Gompertz model for US currently calls for ~1.9 million cases in total. Based on daily data up to now. If social interaction policies change in either direction, number will change. If testing identifies asymptomatic cases, it will go up (with the benefit that their social interactions will go down).
    Fatality rates are still variable across regions. Worst in Italy, above 10%. Lowest in Germany ~1%. Calculated in the same way, US currently fatality rate is 3.8%.
    #1179 tochatihu, Mar 29, 2020
    Robert Holt likes this.
  20. bisco
    52,832
    i wonder if dna plays a part.
    npr: 'authorities in wuhan still not sure if asymptomatic people are contagious'
