Satellite tuner
Discussion in 'Prius c Audio and Electronics' started by Jomo123, Jul 14, 2023.
  1. Jomo123
    Jomo123 Junior Member
    Upstate New York
    I installed a nice Alpine system in my car and it sounds amazing. I do have a few questions.
    1)Is the satellite turner external to the radio?
    2)If yes, does it just plug into the Alpine with or without an adapter plug?
    3) If the tuner is inside the radio, can it be removed? How?
    Thanks,
    Jomo
  2. Jomo123
    Upstate New York
    I meant to add that I have a 2013 prius c
  3. Tombukt2
    Tombukt2 Senior Member
    13,879
    2,521
    Durham NC
    I would think the literature that came with the Alpine would tell you all of that what Alpine number did you buy like 7618 or something then I could look it up I guess I don't know You tell me actually can you tune satellite radio right now or is that why you're asking if it's external to the radio because it doesn't work? Or what's the radio not doing?
  4. Jomo123
    Upstate New York
    Is the satellite tuner that came with the 2013 prius c internal to the radio? If yes, can it be removed? Can I please have those instructions? If the tuner is external, then where is it?
    Thank you,
    Jomo
    #4 Jomo123, Aug 15, 2023
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    All of your questions are dependent on what model of Alpine you have......
    and they should be asked of them.
    #3 strikes me as nonsense. Why would you care ??
  6. rjdriver
    rjdriver Active Member
    411
    172
    Rhode Island
    Just speculating here, as it was worded strangely, but I think the OP is asking if the satellite tuner portion of the radio that comes in the C (not the Alpine) is separate from the main head unit.
    Jomo123 likes this.
  7. rjparker
    rjparker Tu Humilde Sirviente
    11,152
    6,989
    Texas Hill Country
    No it is not separate in factory radios and can’t be removed.
    Assuming your alpine is satellite compatible you need to install a $70 SiriusXM tuner.
    #7 rjparker, Aug 16, 2023
