Save Charge for Going up steep hills
Discussion in 'Prime Fuel Economy & EV Range' started by Gen3PP, May 20, 2019.
  1. Gen3PP
    Gen3PP New Member
    29
    Maryland
    Going up steep hills in HV mode puts the Prime outside it's Eco zone (on Eco/ICE display). If you use EV in these climb situations you can avoid this mpg hit since the ICE is not running.... Save your battery for climbs on longer trips.
  2. schja01
    schja01 Senior Member
    1,853
    1,229
    Chicagoland
    2024 Prius
    Limited AWD-e
    You can use Charge Mode in anticipation.
  3. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    The same amount of power is required to get the car up the hill at the same speed, regardless of whether it comes out of your battery or your fuel tank.
    At low speeds, you might see some efficiency gain from EV due to the higher low speed torque, but at higher speeds I suspect it will be a wash.
    I experimented with this on a recent trip that took me through the mountains of West Virginia and Pennsyvania. I found that I needed to run EV going up some hills to make room for recharging on the subsequent downhills. Other than that, at highway speeds I just left the car in HV mode unless I needed regenerative braking, then it was EV and B mode on the downhill. I found that keeping the engine RPM below about 3000 RPM when climbing provided reasonable speed control and the instantaneous MPG didn't drop significantly.
    jerrymildred, kevin.c and Curlyone like this.
  4. Gen3PP
    Gen3PP New Member
    29
    Maryland
    ICE operate efficiently at low loads. There was a race between a BMW and a Prius. The Prius went as fast as it could and the BMW followed on a closed track. The BMW got better MPG. My gauge goes way below 25mpg and out of the ECO zone. Try it; then we can talk.
  5. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    I may be missing something. Try what?
    Did you mean inefficiently?
    #5 jb in NE, May 21, 2019
  6. fuzzy1
    10,603
    It needs the same amount of mechanical energy delivered to the wheels. I think OP is instead counting 'fuel' before conversion to mechanical energy. We do know that the Gen3 ICE is less efficient at this conversion at high power levels, as shown on its BSFC chart. Gen3's chart is flatter / broader than Gen2's chart, but I don't recall seeing a Gen4 or Prime chart.
    I.e. intentionally flog the Prius, while having the BNW draft behind it. (I remember Green Human John doing this with a VW TDI too, out on the open highway). I'm not taking such biased tests as definitive.
  7. Gen3PP
    Gen3PP New Member
    29
    Maryland
    You try to help and all you hear is ... Obviously some people don't care about mpg (just drive the car, it will get good mileage, don't think) .No wonder the forum has gone down hill.
    In general these engines are tuned to get the best efficiencies at low rpms (1200 or so). There are less mechanical losses running at lower rpms. 30 years ago most 4 cylinder engines operated at above 2000rpm at almost all times while in drive (not going down hill... for those who want to go to troll town). These older engines would lug at these low rpms, which would cause damage.
  8. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Perhaps I'm not understanding the points you are trying to make. You noted that ICE are most efficient at light load, which I don't think is the case. Low RPM and big throttle opening are efficient because they minimize pumping losses, so I follow the low RPM discussion.
    On a recent long road trip with cruise on, level ground, various speeds, I don't recall seeing the ICE running as low as 1200 unless I was going below about 45 mph. At 73 mph by GPS, it was typically 1800-2000 rpm, which is still farily low speed. About 55 mpg indicated by the car at that speed.
    Why wasn't the engine at 1200 rpm, if that is the most efficient speed?
    I would be interested in a link to this event, so we can see exactly what they did and the results.
    #8 jb in NE, May 22, 2019
  9. Salamander_King
    Salamander_King Senior Member
    11,024
    8,972
    New England
    Humm, but steep uphill also uses a lot more EV power as well. If I use EV on a steep uphill, I will lose precious EV miles. I would rather be able to drive 35 miles on the flat road than using the same battery power going 15 miles of uphills. I need to perform the balancing act.
    bruceha_2000 likes this.
  10. Gen3PP
    Gen3PP New Member
    29
    Maryland
    You hint,
    Troll.
  11. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    So I take it there is no reference for the BMW experiment, nor thoughts on the engine speed that the Prime actually runs.
    Asking for further information is now considered trolling, I assume.
    #11 jb in NE, May 22, 2019
  12. Gen3PP
    Gen3PP New Member
    29
    Maryland
    I reported you; that is my thought. I stand by my initial assessment jb.
    Per the rules: you can be booted for:
    "Section l. "stalk" or otherwise harass another;"
    #12 Gen3PP, May 22, 2019
  13. fuzzy1
    10,603
    No, that isn't even close. The Gen3 engine is most efficient at around 2000 RPM, but has declines only a few percent out at 4000 RPM. See the BSFC chart here:
    2010 Prius 2ZR-FXE engine efficiency map | PriusChat
    :eek:
    He is not at risk here.
    #13 fuzzy1, May 22, 2019
  14. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    I'll agree with that. My turbocharged 2.0L VW TDI was pretty much a dog at 1200 RPM. They set the car up for boost at about 1700 RPM, so about that range it developed a lot of torque. Below that, gutless. I generally needed to be above 55 mph just to run in 6th gear. 60 mph on that car top gear, 1780 RPM.
    The newer Corvettes will get over 30 mpg highway in top gear, and if I recall they run at about 1500 RPM.
    By comparison, highway tractors (Class 8 trucks) with 12-14 liter turbo-diesels typically run in the 1200-1400 RPM range, depending on gearing.
    Back in the days before computers, variable valve timing, turbos, etc, the optimum fuel economy point was generally specified as the max torque point.
  15. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    There may be a troll here but it isn't @jb in NE
  16. Gen3PP
    Gen3PP New Member
    29
    Maryland
    Birds of a feather stick together.
  17. Leadfoot J. McCoalroller
    8,163
    7,667
    Pennsylvania
    2018 Prius c
    benagi likes this.
  18. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Thanks. Prius 17.2 mpg? I didn't think that was possible - foot on the brake and gas at same time? And, they never specified how they measured the fuel consumption - calibrated meters, dash display, etc.
    Interesting exercise, but I don't see a lot of scientific rigor in that one.
    And, if this were repeatably true, then manufacturers would not be abandoning larger engines for smaller boosted engines to improve fuel economy. The Ford 2.7L twin turbo in the F-150, for example. Ford small SUV's and even Mustangs with the 2.0L EcoBoost, as another example.
  19. Leadfoot J. McCoalroller
    8,163
    7,667
    Pennsylvania
    2018 Prius c
    The scientific rigor? I think it was just off-camera chatting up the craft service girls...
    But seriously that's rather my point. They came up with a number that might be believable, but at least now we can correctly identify the most popular account of a BMW outscoring a Prius in an economy test.
    Edit: maybe imperial gallons? I can't remember TG's convention for units.
    fuzzy1 and jb in NE like this.
  20. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    Thanks. Now that really was one of the stupidest things I've seen those knuckleheads come up with. There are so many things wrong, I wouldn't know where to start. :ROFLMAO:
