Saving setting in car while changing battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sheepdog, Sep 1, 2013.
  1. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    If I am taking the old battery out and inserting the new Optima, how do I maintain the settings of the car for drivers window, radio presets, etc?
    If I connect the charger to the front hood connectors wouldnt that cause a shock hazard while taking the battery out? Not sure the best way to do that part. or is it even needed? If it is just the drivers window and radio presets so what?
    And comments would be welcome. Thanks
  2. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
  3. Britprius
    Britprius Senior Member
    5,194
    1,914
    Herefordshire England
    A charger or small jump battery connected under the hood will save the settings. At 12 volts there is no shock risk.
    The main problem is the positive battery terminal will remain at 12 volts even when disconnected from the battery.
    If the terminal touches any of the body while disconnected but being supplied with 12 volts from the front of the car. One you will loose the settings anyway.
    Two if your using a charger you will almost certainly blow it's fuse.
    Three if your using a jump battery you could blow the high current fuse built into the battery terminal.
    Four it also makes it dangerous because any tool used to fasten the positive battery terminal that comes into contact with bodywork will carry a high current giving the risk of burns. The reason why when changing a battery always undo the negative first and re connect last.
    My suggestion if you intend doing it this way is to very carefully remove the positive terminal and fasten it inside a plastic bag or rubber glove.
    John (Britprius)
    SteveLee likes this.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Do yourself a big favor. If you have to ask how to do this your not ready to do this. This is the last car in the world you should muck around with chargers etc while changing out the battery. So easy to cause big $$$ damage to the Inverter on this car by inadvertent spark or surge. Concentrate on the battery swap.
    Takes 30 seconds to reprogram the radio.
  5. nh7o
    nh7o Off grid since 1980
    1,686
    338
    Hawaii
    The Prius will keep its settings below 9V ( I checked, inadvertently), so you can use a very small 9V battery with clip leads to the jump points at the front of the car. There is too little current capacity in a 9V battery to do any harm. Have a helper do this as you disconnect the 12V battery. There is enough capacitance in the electronics to hold the voltage for a few seconds with no battery connected. Or, use a diode in series to isolate the 9V.
    A battery charger puts out unknown voltage with no load, so it is not the way to go unless verified.
    But indeed, it might take longer to get that together than to reprogram the radio and windows.
  6. Blanchie
    Blanchie New Member
    Hi- I just bought a NOCO GB20 for when I'm heading out and I accidentally didn't shut the trunk hard enough. I read the instructions and it said Do not use on anything but a lead-acid battery. Anyone one know which jump starter works with an 08 prius 12v?
  7. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Prius 12V battery is lead acid battery. Any jump starter pack that’s either 3 cell lithium (the new ones) or 12V lead acid (the old ones) work fine. And actually you could jump Prius with almost any battery that has the correct voltage you don’t need much current to start a Prius.
