scammed need help
Discussion in 'Gen 3 Prius Main Forum' started by qnami, Apr 29, 2020.
  1. qnami
    qnami Member
    37
    34
    san francisco
    I mentioned numerous time that I jave been title jumped. I looked service record as well and like you mentioned, no Egr service and no water pump job, just routine oil change. I decided to just ride it till it fails. I really dont have high expectations from DMV or LEOs to find this guy nor i am interested in spending money on 300k miles car.
  2. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    I was not familiar with the term "title jump(ed)" and hadn't looked it up, so it happens that I came up with an explanation that matched that term of which I had never heard.
    Johnny Cakes likes this.
  3. TinyTim
    TinyTim Active Member
    414
    241
    Seattle
    I will chime in. Could we get a pic of the odometer? I want to see the mileage. It's possible the OP was looking at Trip A or Trip B thinking that was the actual mileage without scrolling through to the Odo. It makes no sense that the Prius was serviced about every 3 weeks or 5K miles. If it was an uber. They would drive that thing into the ground and not think twice about an oil change.
    It's not easy to roll back a digital odometer. The analog ones were a joke compared to a modern ODO. I would go into the Toyota dealership and give them the vin number and ask them when it was serviced what the mileage was on the last two or three services. All you would have to tell the dealership is that you suspect the Odometer has been tampered with. That would confirm if the Odo has been tampered with when the OP bought the car. Considering the craziness of this thread. I think we need to see a picture of the Odo with the actual mileage displayed.
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Here, we're like that talk show The View; we all just want to speak and not listen to each other.
  5. qnami
    qnami Member
    37
    34
    san francisco
    Took it 2 days ago for DMV investigation. I bought it 2 months ago at feb 24 and drove 2 months
    TinyTim likes this.
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I think the skepticism, or more precisely the questioning here is mostly just born out of the language used and description of the vehicle itself.
    Odometer fraud aside, while I believe a vehicle ONLY as old as 5 years old can be made to look like it has less miles on it, the description of the vehicle as being in BOTH in operational and cosmetic pristine condition is hard to swallow.
    I hope for the OP's sake, 100,000 miles or more can be put on the vehicle with good reliability.
    But the questioning comes with descriptions such as these:
    " it doesnt burn any oil nor any vibration, suspension is pretty stiff except little misalignment. I am getting 48mpg "
    " Engine bay? all the hoses wire connection like new."
    " mechanical condition of the car...48mpg, everything firm and smooth no funny noises "
    " 2 months it didnt burn oil and drove stopped smooths. Suspension firm with bad SF roads. I recently went under for oil change and oil pan and undrcover was pretty good shape as well."
    Since it appears the OP was defrauded, I hope the vehicle is in great shape and does continue on, with a reliability and a lot more possible additional miles.
    But I think what is hard for a lot of the gallery to accept is the proclamation that it has 300,000 miles on it, but the overall condition of a nearly new vehicle from a mechanical standpoint.
    I've owned used vehicles with mileage approaching just 130,000+...and they start to feel different. You start to get wear on shocks, suspension, the engine itself. Commonly you don't get to 150,000+ without some engine oil burning.
    Even though YES Prius exist and operate with 300,000+, the truth is there is no way to sugar coat it, 300.000 miles is a lot of miles on a mechanical vehicle.
    So if I can speak for the gallery, I think the questioning comes from the contention that the vehicle simultaneously has 300,000 miles on it, but shows absolutely no mechanical operating signs that would be consistent with a vehicle with that mileage.
    But good is GOOD.
    I hope the vehicle is in great shape, and the OP get's many years, miles more out of it.
    Data Daedalus and Johnny Cakes like this.
  7. TinyTim
    414
    241
    Seattle
    You should take the Prius to Toyota Town and show them the ODO. Then have them run the VIN number of the car and they can pretty easily tell you what the ODO readings were in the last year. That way you can figure out when the ODO was rolled back. You don't need to worry about who serviced or owned the car prior. Let the DMV worry about that part.
  8. NewHybridOwner
    607
    283
    W. Michigan
    But both the original official owner and the "seller" (even if he can be located: the phone number no longer works; is the address even genuine? The transaction could have taken place in the parking lot of an apartment complex far away from that seller's true residence) can deny that they rolled back the odometer.
  9. TinyTim
    414
    241
    Seattle
    You make a valid argument. I am more interested in the service records of the Prius. The Toyota dealership always inputs the mileage on the Odometer. Even thought they are simply writing what they see. If the dealer goes through their service records. They can see when the odometer went from 250,000+ down to 39,000 miles.
  10. qnami
    qnami Member
    37
    34
    san francisco
    It's all about proving "intent of committing fraud". Based on the cafrax both mine and scammer provided, there is record of smog done at Feb 4th. Fake car fax is showing Feb 15th 2020 with 38k miles even though on the cover page the car fax is pulled out at 2017 (which proves it has been forged) And my car fax shows it did pass smog on same date with 297k miles at different smog station. I have text record with scammer sending pic of fake carfax when I asked him for vin number so i can run my car fax.
    Also to mention fake smog certificate scammer provided with actual date of Feb 4th with altered mileage and location is sufficient.
    Hardest part is to find this guy if actual owner and scammer is different individuals which I am afraid it is at this point
  11. qnami
    qnami Member
    37
    34
    san francisco
    Now I have been looking around and I have found few people who got scammed with identical ways. i guess this scam was there for a while. I also attached my "300k miles engine bay". Interior is even nicer
    The Electric Me and bisco like this.
  12. NewHybridOwner
    607
    283
    W. Michigan
    I've already seen Toyota's official records for that vehicle (plugging in the VIN that CarFax told me corresponded to the Registration Plate shown on the February smog certificate). The last service recorded was on 1/6/2020 at Toyota Town when the odometer reading was 291,230 miles; a 10K mile service was performed, but the owner chose not to have the recommended engine and inverter coolant replacements performed.
    So the odometer was rolled back between 1/6/2020 and whenever it was in February that the smog check was done. Whether that roll-back was done by the original owner or by the presumed intermediary (who could have been acting on behalf of the original owner for all we know) nobody knows at this point.
  13. bisco
    52,757
    ya gotta give the guy credit, he's great at what he does. terrible, but great
    qnami likes this.
  14. Borninblue
    Borninblue Active Member
    233
    158
    Cleveland, Ohio
    Engine bay looks brand new! Unbelievable...
    qnami likes this.
  15. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    First of all, if the vehicle is worth $8,200 (as per Car Fax) then you paid $3,800 above actual value. Scammer did a lot of work to make that money. In fact, getting it that clean and running so well, he probably could have gotten more than $8200 for it. To actually make a living doing this kind of stuff, he must be very efficient and must pull this scam quite a few times per year.
    That said, do the records show any brake work (beyond fluid exchange)? Brake pads last a long time in Toyota Hybrids but not usually 300,000 miles. If no brake work done in a long time, you should have them thoroughly checked. Scammers care about how the vehicle appears to the perspective buyer, not the true underlying condition.
    Also, if there are no records of the hybrid battery health being checked, you can do that by getting an OBDII bluetooth enabled adapter and then running a smartphone app such as Dr. Prius. I would do that.
    #95 royrose, May 3, 2020
    qnami likes this.
  16. The Electric Me
    9,083
    5,801
    Sad that this is such a common scam.
    That was my fear almost from the start of reading this thread, that this guy was a real professional.
    My secondary fear would be that IF he's a professional with this scam, finding him would probably be very difficult. He's probably executed this in a way that covers his tracks.
    But good luck.
    qnami likes this.
  17. The Electric Me
    9,083
    5,801
    Keep in mind chronologically this is only a 5 year old vehicle.
    Doesn't surprise me that cosmetically it could be made to look very good.
    Again in a lot of used car dealerships, pop the hood on even much older vehicles and if the engine was steam cleaned and detailed they can look amazingly good.
    qnami likes this.
  18. qnami
    qnami Member
    37
    34
    san francisco
    Well previous owner religiously took the car to toyota dealer every 5-10k miles. I am crossing my finger that it would show some positive effect on engine and transmission's conditions. He did replace front brake 100k miles ago. I am checking CL and other used car market value and I think it will be hard to sell my car for 8500 dollars. Especially altered odometer and 2 accidents ( I believe its still clean title since title I received doesnt say salvaged). Like you said I hope I only took 3500 dollars loss man. And if it last another 150k I say I will be feeling little better
  19. bisco
    52,757
    i think we'll all be (y)
  20. Borninblue
    233
    158
    Cleveland, Ohio
    Good point, I’m used to looking at engines which are exposed to salt and harsh winters. You should my engine bay with 150K on 2010. Rust is on every bolt.
