Scan gage
Discussion in 'Gen 3 Prius Technical Discussion' started by Kennewick Man, Mar 17, 2012.
  1. Kennewick Man
    Kennewick Man Junior Member
    42
    Kennewick,Wa.
    I just bought a scan gage & i read that quite a few people have them. Think I have the set up installed correctly it was somewhat complecated for me.:confused: I know you can show up to 4 functions @ one time, so I would like to know what are the most common 4 functions that you most often show on the screen at one time. ;)
  2. Sabby
    Sabby Active Member
    295
    127
    SoCal
    I find that I use RPM, Amps, Water temperature and Power in Kw the most. Once the car is warmed up (beyond 160 degrees) I switch the water temp to instantaneous MPG. I sometimes use the Soc state of charge gauge.
    Some of these are x gauges.
  3. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    Agree .... those are the most important stuff you MAY want to know but can not get from the car directly ...
    good luck and later you should find even more usefull thing out of ScanGauge ...
    I am not selling the thing !!!!
  4. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    These have been favorites...
    FTW - Coolant temperature. This is by far the most informative. Heater & EV behavior is based directly upon this value.
    RPM - This gives you a strong appreciation for what the power-split device is able to deliver in conjuction with the 2 motors. Sometimes the engine runs at surprisingly low speeds. And of course, sometimes not at all.
    MPG - That's nice to know, since the gauge goes beyond the 100 limitation of Prius itself.
    MPH - Used for the filming of my Prius videos.
    ...though my gauge is older and doesn't have newer goodies like SOC (State Of Charge for the battery).
  5. Kentwang
    Kentwang Junior Member
    46
    Oakland, CA
    I have:
    RPM
    Water temp, because I blocked my lower grill.
    Mile per gallon
    Fuel use per hour.
  6. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I normally keep the following up:
    Coolant temperature
    RPM
    MPG
    Cabin temperature (Once close to setpoint I vary this one.)
  7. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    On the GenII I generally use:
    RPM
    MPG
    Engine Coolant Temp
    SOC
    On my new GenIII I now use:
    RPM
    MPG
    Loop (open/closed)
    SOC
    Because the GenIII and Scangauge don't always get along, I used the Loop gauge to help tell me when the ICE is truly off so I know when I am in glide or warp stealth mode. Once I learn the car I will switch this to engine coolant temp.
    Loop (open or closed)
  8. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    I think you meant FWT (Fahrenheit Water Temperature), not For The Win. :)
    For me, I have no Gen 3, but I have no use for MPG. I never even bothered trying to calibrate my SG so that the MPG figures are ok. I figured, I already have 2 measurements (manual calculations and MFD). Why bother w/yet another estimator?
    I don't need MPH as I've already got that in front of me.
    On my Gen 2, I mostly use (I might have the capitalization wrong):
    Bta - to see HV battery amps going in/out
    RPM - ICE RPM
    IGN - ignition timing, so I can use Super Highway Mode
    FWT - already mentioned
    If the ICE is warned up, I sometimes switch FWT to Soc to see HV battery SOC %.
  9. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Andrew, the GenIII doesn't show instantaneous mpg like the GenII did. Even then it couldn't tell you when you were in a true glide or warp stealth since mpg stopped at 99.
  10. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Ahh, I see about the Gen 3. Right, there's only the vertical curved bar graph to the right of the speedometer.
    Yep on the 2nd point. I never really paid much attention to true glide vs. "warp stealth". :confused: Maybe I should. For me, I'm not totally convinced that the ICE is drawing no fuel unless RPM == 0 or there's something that tells me for certain there's 0 fuel flow. On my Gen 2, if I pulse and glide <41 mph, I look to see if ICE is off by checking for RPM == 0.
  11. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    I use :
    Loop
    Wth
    ITF
    M2F
  12. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    RPM
    ICE Coolant Temp
    HV Battery Amps
    various things, presently set for Inverter Coolant Temp
  13. MNGoan
    MNGoan New Member
    La Crescent, MN
    FwT
    RPM
    MPG
    SOC
    sometimes battery voltage
