Scan gauge 2, worth it or not?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by abra, Nov 29, 2013.
  1. abra
    abra Member
    197
    Austin, Tx
    Three Touring
    My in laws would like to buy me a toy to use with the prius, my bother in law recomends a scan gauge 2.
    Any input?
    I would rather update sway bar for the same price (Rav sway bar kit $134)
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    I suggest you get the TRD rear sway bar rather than the front.
  3. Mendel Leisk
    42,352
    I got ScanGauge maybe 2 years back. There are lot of gauges that can be displayed, it can show 4 at a time. It has the ability to calculate your miles to empty, and mpg, tank-by-tank, but I gave up on that, pretty much from the outset.
    My use of it is very simple, this is what I've settled on:
    RPM <mainly so I know definitely if the engine's on or off.
    Coolant Temp <useful to know what "stage" of warm-up you're at, what your block heater has accomplished, if you're grill block is not excessive, and so on.
    MPG since last start-up <lets you know how you're doing, for the current trip
    Instant MPG <same info as the bar graph in dash, but much more detailed
    All in all, I pay attention to it pretty much every time I'm behind the wheel, even with the limited use I've settled on.
    I just adhered it to the dash, directly behind the steering wheel, with a couple of loops of masking tape on the base. It comes with Velcro strips you can adhesive-on to dash and base, but I was reluctant, thought it might leave marks. My setup was supposed to be temporary, but it's worked out fine.
    (I guess grill block and block heating are not big in Texas...;))
  4. abra
    abra Member
    197
    Austin, Tx
    Three Touring
  5. gliderman
    gliderman Active Member
    751
    225
    SGII! Mine is set to Coolant Temp, RPM, Brake Friciton, and Cab Temp. Another favorite setting is fuel remaining.
  6. abra
    abra Member
    197
    Austin, Tx
    Three Touring
    Next ?
    Best place to buy one, in law says that the local parts store (Oreilly's) has them.
  7. vskid3
    vskid3 Active Member
    773
    228
    $150 to 160 is about as low as they usually go. Autozone and another store (might have been Advanced Auto) had coupon codes a couple months ago that took so much off your whole order, that's the cheapest I've ever seen for a new one. They might have something similar going on now.
    Another option if you have an Android device is the Torque app with a cheap ELM327 bluetooth scanner. You can do a lot more with it, but the Scangauge is easier to leave in the car.
  8. Mendel Leisk
    42,352
    Assuming the ScanGauge:
    CleanMPG sells them, sort of a good cause. Hang on, they're not for sale here are they?
  9. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Some of us call that favorite: SOC ;)
    I have both, always connected via a OBD-II splitter. There's no contest which is more convenient: Scangauge.
    Since I have the plug-in model and live in the north, being able to see SOC (battery level) is helpful. The range guestimate is all over the place with daily temperatures and engine use all over the place.
    Seeing coolant temperature is priceless. Knowing when heat is available and how much is quite nice. Some might say it leaves you with a warm feeling. :rolleyes:
  10. ou812
    ou812 Junior Member
    40
    Make sure you get the newest version I purchased an older one and had to send in to be updated for a additional fee. But they are very handy indeed, I got mine at Amazon along with the rearview mirror mount.
  11. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
  12. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    I just checked and although code DOW48 is good for $50 off at Advanced Auto Parts, I see they've now reduced the price on the ScanGauge to $139.99 and marked it as ineligible for any further discounts.
    It was a great deal while it lasted, as the price with the code (when it was working) was $109.99.
  13. elementnomore
    elementnomore Member
    136
    44
    Los Angeles
    Do you have the correct coolant temp code? I can see the google doc but I think mine is displayed in C And not F.
    Thanks!
    Turn off signatures in Tapatalk Tapatalk
  14. abra
    abra Member
    197
    Austin, Tx
    Three Touring
    Come on mail UPS
  15. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Just for your additional info, I typically monitor the following:
    Hot Summers:
    • HV Battery Temp Sensor #2 (middle or hottest)
    • HV Battery Fan Mode (speed)
    • Cabin Temp
    • AC Watts
    Winters:
    • ICE Coolant Temp
    • Cabin Temp
    • Battery Temp Sensor #2
    • Average MPG
    Good luck with your new SGII. The best part is once you mount it above the steering column (or wherever) it is in line of sight and totally hands free.
  16. abra
    abra Member
    197
    Austin, Tx
    Three Touring
    At least I won't have a dash full of gauges, like my old hot rods had.
    jdcollins5 likes this.
