scan gauge goes blank
Discussion in 'Gen 2 Prius Technical Discussion' started by donalmilligan089, Mar 23, 2009.
  1. donalmilligan089
    239
    22
    virginia usa
    When ice goes off (while stoppig for traffic or slowing down) sgII goes to sleep in 15 seconds. Going down hill at 45 mph or better it stays on. Bothersome to hit home button often .Any answers? Dogsgofish
  2. halpos4
    halpos4 "Taxi"!
    377
    24
    Ireland
    You have to set it for Hybrid,it's in the manual!!
  3. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    +1 to Hal. When the engine shuts off, the ScanGauge thinks the ignition is off, and shuts off after 15 seconds. There's a setting to defeat that. See your SG manual.
  4. dogfriend
    7,512
    1,188
    Carmichael, CA
    You need to set the mode to "Hybrid".
  5. donalmilligan089
    239
    22
    virginia usa
  6. halpos4
    halpos4 "Taxi"!
    377
    24
    Ireland
    You're welcome!!
  7. tortus
    tortus New Member
    minnesota, USA
    My ? exactly. But I have the original scangauge 1 and it does not come out of "sleep mode" when the ICE comes back on and there is no hybrid setting. Thanks to this forum, I now know that buying a SCANGAUGE 2 will solve this problem.
    This is my first post after registering and I had to do it as a reply because I do not know how to create a post after logging on a forum. Can anybody help me?
  8. dogfriend
    7,512
    1,188
    Carmichael, CA
    Go to the main page of forum that you want to post in and click the "New Thread" button near the upper left corner:
  9. hschuck
    hschuck Member
    385
    17
    bay city, ca
    Continuing off topic . . .
    Tortus
    Only the early versions of the original scanguage did not have a hybrid mode. It was added to later versions of the original. Depending on when your scangauge was made, it may have the hybrid mode setting. I bought mine (original not II) in late 2005 before the scanguageII came out and it is hybrid compatible.
    Look under MORE>SETUP>FUEL>TYPE for the hybrid setting. If not there you might contact linearLogic to see a firmware update is available.
  10. Frances Greene
    Frances Greene New Member
    Austin, TX
    This is actually a response to a posting you made several months ago regarding a TAS for your Prius. I have just removed a Bruno Turnout from the passenger side of my 2006 Prius and put the original seat back in. Do you still need one?
