Scan Gauge II new owner questions
Discussion in 'Gen 2 Prius Technical Discussion' started by daveleeprius, Mar 23, 2007.
  1. Pinan
    Pinan Member
    173
    Murrieta, CA
    If you're referring to this entry:
    Pack current [Amps]
    TXD: 07E321CE
    RXF: 056186CE0000
    RXD: 3810
    MTH: 0001000AF333
    I just confirmed that I can not have SOC and AMP active at the same time. AMP will show, SOC will not. I had not tried those two together before.
  2. zeeman
    zeeman Member
    211
    I am guessing that it has to do with data stream that is pulled off HV battery,
    maybe it is scangauge limitation
    btw, that is a nice red color.
    red is so cool, as cool as that deep blue color
  3. tls1
    tls1 Junior Member
    17
    One more question - Is there any way to program the SG2 to display the transmission temperature?
    Thanks
    Ted, 07 and 08 Prius
  4. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    Someone said in another thread that no one has figured out the code yet. :(
