Scangauge 2 Question
Discussion in 'Gen 3 Prius Accessories and Modifications' started by DP200248721, Oct 24, 2012.
  1. DP200248721
    DP200248721 Active Member
    155
    415
    Suisun City, CA
    ***SOLVED***For those who own the Scangauge 2, does yours shut off when in EV mode? As soon as RPM hits 00 the entire gauge shuts off, which of course is understandable considering most standard vehicles aren't still in motion after the engine turns off. Nevertheless, I've searched the forum and google but couldn't find a definitive answer to this. Is there a code for an Xgauge that would enable the gauge to stay on while in EV mode? Thank you for your time and sorry if this has been brought up before ,but I've taken time to search and have uncovered nothing on the subject.
  2. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    There should be a mode on the SG for hybrid vehicle mode. I believe it's under More > Setup > Fuel > Type.
    You don't need to enter any XGauges to prevent the shutoff. I don't think entering any would help either.
    DP200248721 likes this.
  3. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    You need to set the Fuel Type to Hybrid.
    For Firmware 3.xx, Go to MORE -> SETUP -> FUEL -> TYPE and select HYBRID.
    For Firmware 4.xx, Go to MORE -> SETUP ->FUEL TYPE and select HYBRID.
    Vincent
    DP200248721 and bwilson4web like this.
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    There is also a Sleep Mode setting under the Advanced Settings. Change the Default Value to Loss of Comms.
    This is on my 4.05 rev firmware.
  5. DP200248721
    155
    415
    Suisun City, CA
    Ugh... of course it would be something as simple as that.. didn't even realize there was a hybrid option in fuel settings. Thanks everyone, greatly appreciated. Gonna go do that right now lol Thanks again!
  6. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    674
    179
    Vancouver, WA
    :LOL: Didn't you look at the set-up directions when you bought it? It showed me exactly how to set up mine when I bought it. :D
