ScanGauge II IGN variation in S1a stage?
Discussion in 'Gen 3 Prius Technical Discussion' started by srivenkat, May 11, 2013.
  1. srivenkat
    srivenkat Active Member
    596
    93
    IL
    Folks,
    I have an SGII (firmware 4.02) that never showed a negative IGN (not even in stage s1a) before I cleaned the MAF sensor (which wasn't noticeably dirty, just thought I would clean it at 48K miles). Now it does show negative IGN in stage s1a but the value is not the constant -5 that I remember reading somewhere it should show in s1a. It varies among -1, -6, -2, etc.
    Anyone else see this behavior? If not, what values do you see in s1a? Before I cleaned the MAF sensor (took it out, sprayed CRC cleaner and put it back in), I would see a - AFTER the RPM number in s1a, but now I don't see the dash anymore there, but before the IGN number, but what causes concern to me now is that the number varying in s1a.
    Thanks.
  2. FrankTiger
    FrankTiger Member
    63
    118
    Madrid, Spain
  3. Sergio-PL
    Sergio-PL Member
    160
    46
    Poland
    My own Prius shows IGN = -5 in S1A. Allways. Read by Torque + ELM327 BT.
  4. srivenkat
    596
    93
    IL
    I wonder why mine changes every time and varies while in s1a stage. Anyone else that sees this variation during s1a? Anyone else that sees a constant -5 IGN in s1a? Thanks.
  5. srivenkat
    596
    93
    IL
    Looking again at Frank's post above, I see a chart that shows IGN settings lower than -5 based on coolant temp.
    Frank: is the coolant temperature shown on the map, the temperature at the start of s1a or does it show the IGN varying on the fly as the coolant temp increases during s1a? Thanks.
  6. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    My timing varies between +2 and -3 in that stage per Dashcommand.
