ScanGauge on the C
Discussion in 'Prius c Main Forum' started by WD0AFQ, Jul 27, 2012.
  1. WD0AFQ
    WD0AFQ Active Member
    619
    152
    Dexter, Mo.
    Hooked up my ScanGauge on the new C. The thing turns off when running on battery. Does anyone else have this problem? I have to turn it back on. It is an older one that I took out of my Vibe. Also, it has only whole numbers so I had to set the tank size to 10 gallons. Will a new version ScanGauge have these same issues?
    Thanks,
    Dan
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Nope. You won't either, once you change the FUEL type to HYBRID.
  3. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    You can maybe get an upgrade. You'd have to look HERE to see if yours is qualified.
    The site also has users manuals. I set my C up for SLEEP EVENT/No Comm and it goes off after I shut the car off. I have the ScangaugeII.
  4. WD0AFQ
    619
    152
    Dexter, Mo.
    Thank you. I set it to hybrid. Trying to take in too much information on our first day with a hybrid.
    Dan
