Scangauge would be a great tire pressure monitor
Discussion in 'Prime Technical Discussion' started by bwilson4web, Oct 23, 2017.
  1. bwilson4web
    15,523
    With a four, data point display, it would be great if we could get Xgauge definitions for the tire pressures from the TPS. I'm thinking use miniVCI to stream record the TPS while 'wire tapping' the OBD traffic. The convert to Xgauge definitions.
  2. Mark57
    2,945
    2,736
    OK
    You mean like this . . .
    Attn: ScanGauge II Owners! Individual tire TPMS data! | PriusChat
  3. chogan2
    chogan2 Senior Member
    1,066
    756
    Virginia
    Bob,
    Greetings from the distant past. I think the last thing we discussed was pending federal regulation to require all hybrids to make noise at low speeds. I can tell from the sound of my wife's 2021 Prime that we lost on that one.
    This is an old thread, but I thought I'd reply.
    Using the Scangauge for monitoring tire pressure is both easy and practical on the newer model, the Scangauge 3. That one will read the Xgauge codes automatically, and can display up to 27 different gauges, 9 per page, 3 pages. The upshot is that I've set up my last page of gauges to monitor tire pressure and temperature.
    Scangauge also now lists the Xgauge codes, for use on the models where you have to enter those manually:
    » TOYOTA – LEXUS – SCION
    Chris Hogan
    Meg&Bear and bwilson4web like this.
  4. bwilson4web
    15,523
    The sad thing is the turn bias suggests there is a driver side bias. The close windshield A pillar blocks one eye and our built-in blind spot blocks part of the other eye. It is easy when making a driver side turn to miss anyone crossing the street on the driver side.
    My Tesla has three forward cameras including one wide angle, short range. The car sees side crossing pedestrians that a human would miss.
  5. chogan2
    1,066
    756
    Virginia
    I hear that. Took me a while to get use to the broad A-pillars..
    The Prime has some sort of forward-looking collision warning, that in theory will pick up pedestrians and bicyclists in addition to cars.
    I know it'll pick up a stopped object straight ahead of you, but I'm not sure how useful it is for avoiding pedestrians while cornering.
    OK, it's useless for avoiding striking a pedestrian while turning. The manual says it will not issue a warning "When a detectable object is not
    directly in front of your vehicle"
    So, point taken.
    The car now makes noise for the safety of blind pedestrians in parking lots. It's not clear that addressed the biggest low-speed pedestrian safety issue for the car.
    Maybe if I get motivated, I'll download that National Highway Transportation Safety Administration dataset that I used for the analysis of Prius pedestrian collisions, and see if there is any apparent excess risk of driver's side pedestrian collisions in a Prius.
    Meg&Bear likes this.
  6. Mendel Leisk
    38,726
    It’s not just the blind; cars can be approaching from the side or behind, and nobody has foolproof radar alertness.
