ScanGauge Xgauge code for outside temp
Discussion in 'Knowledge Base Articles Discussion' started by Rod F, Jul 10, 2014.
  1. Rod F
    Rod F New Member
    Courtenay, BC
    2002 Prius
    I
    Good day all,
    Does anyone know the Xgauge code for outside temperature for a Gen 1? I live on Vancouver Island and own a US Prius and the outside display is in F and would like to be able to view it in C on my ScanGauge.
    Thanks in advance.
    Rod
  2. drysider
    drysider Active Member
    823
    337
    Liberty Lake WA
    Depending on your version, the units can be set in the Basic Parameters Setup without using an X-Gauge: More-Distance-Fuel Units-Temp Units.
  3. Rod F
    Rod F New Member
    Courtenay, BC
    2002 Prius
    I
    Yes, that will work for displaying C, but I need the code to display Outside Temp. I then would have the option to display F or C as you described.
  4. drysider
    823
    337
    Liberty Lake WA
    Outside Temp: TxD: 07E22101 RxF: 056106010000 RxD: 4808 MTH: 00090005FFD8 Nam: ExF
    This is in Fahrenheit. I do not know if it will convert to Centigrade.
  5. Rod F
    Rod F New Member
    Courtenay, BC
    2002 Prius
    I
