ScanGaugeII work on 2010?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by taxachusetts, Jun 29, 2009.
  1. WE0H
    WE0H Senior Member
    3,247
    528
    I'm in the same boat. I have the ScanGauge II but am clueless how to enter in this data to make it display Prius specific data.
    Mike
  2. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    navguy12 has made an easy to follow scangauge x-gauge for dummies.
    Vincent
  3. AZGeek
    AZGeek Semi-informed Member
    627
    144
    63
    Arizona
    Partial success. I was able to disable the reverse beep via the XGauge codes but have not yet been able to disable the seat belt beeps. :) :(
  4. WE0H
    WE0H Senior Member
    3,247
    528
    I need to do that seatbelt beep thing also. I forgot to ask the dealer to do that but did remember to have them set the reverse beep to a single beep. Maybe today I will install my ScanGauge as it is supposed to rain so I won't be driving it :eek:
    Mike
  5. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    Before I start looking through 27 pages, who can tell me where the instuctions to change reverse beep are? -_-"
  6. jbcarey
    jbcarey Junior Member
    45
    Poughquag, NY
    Go to page 27
    WE0H likes this.
  7. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    Hello from Japan.
    We know sometimes the SG-II does not tell us the correct GPH, LPH or iMPG value in the fuel-cut mode.
    The standard OBD-II PID does not have a direct fuel flow data, and those values are calculated by MAF (mass air flow) value, but the MAF is not always correct such as fuel-cut mode.
    JP Prius enthusiast team found a Gen3 passive CAN frame (CAN_ID:0x3D3:#0#1) tells us real time fuel flow data, then I wrote following X-GAUGE code for lph (liters per hour)
    Column 1
    0 [TR][TH]XGauge[/TH][TH]TXD[/TH][TH]RXF[/TH][TH]RXD[/TH][TH]MTH[/TH][TH]NAM[/TH][TH]Notes[/TH][/TR]
    1 [TR][TD1]Liters Per Hour[/TD1][TD1]03DB[/TD1][TD1]010342D30000[/TD1][TD1]1010[/TD1][TD1]006401210000[/TD1][TD1]lph[/TD1][TD1]x.xx liters per hour[/TD1][/TR]
    It works as expected, and I see 0.00 lph value in the fuel-cut mode.
    Following X-GAUGE code is for gph (gallons per hour), but I have not tested it yet.
    Column 1
    1 [TR][TD1]Gallons Per Hour[/TD1][TD1]03DB[/TD1][TD1]010342D30000[/TD1][TD1]1010[/TD1][TD1]006404470000[/TD1][TD1]gph[/TD1][TD1]x.xx gallons per hour[/TD1][/TR]
    Please test it and enjoy!
    Ken@Japan
    WE0H, fuzzy1, 2009Prius and 4 others like this.
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    ^ JD, let us know if it works (gph). :)
  9. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I'll test it next week after vacation !
  10. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Punched in the codes last night and tried it this morning. The gauge reads zero where expected. Hard to verify if the values are correct but seem reasonable. Thanks for the information!
    jdcollins5 likes this.
  11. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    You're welcome!
    The second part of the MTH (divider), 0121 (lph) or 0447(gph), is the magic number to adjust the displayed values.
    I have tried every effort to match the Prius's mpg numbers, which is approx 6.5% over estimate. :(
    60mpg @ 60 mph = 1.00 gph
    Please try to find how accurate the gph values are by yourself comparing to damn standard GPH values. :)
    Ken@Japan
    HTMLSpinnr likes this.
  12. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Ken,
    I finally remembered to try your gph XGauge yesterday. I monitored it while driving 60 mph yesterday afternoon and again this morning.
    With both the MPG and the gph values being instantaneous, changing rapidly and updating at different times it is difficult for me to get to a steady-state condition long enough to record useful info :)
    I did get a few points to duplicate a few times.
    60 MPH on SGII, 62 mph on display
    gph = 1.00 : mpg =57.6 once, mpg = 58.4 once
    gph = 1.20 : mpg = 48.0 multiple times
    So it appears that the gph value is reading low in the 5-10% range to the best that I can determine.
    It would be nice if someone with the ability to trend these values would monitor MPH, MPG and gph so that we can see a more stable value over some time period to get better numbers.
    Of course this is still a good indication of gph and it does indicate when the ICE starts and stops and follows the HSI once the ICE is up to temp.
    Thanks,
    Dwight
    spiderman likes this.
  13. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I was able to get 1.00 @ 60 once or twice but there are a lot of factors influencing that like wind and grade.
    I found the gauge very informative as a fuel cut-off. When gliding down a slight grade, I found to correlation between 9999 and 1857 mpg and the engine shutter (ignition).
  14. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Yes, I saw 1.0 @ 60 a couple of times too but only for about 1 or maybe 2 scans. I could never get to a steady enough state to get more multiple scans.
    My biggest factor was the grade even being on the coast. The constantly rolling grade makes it difficult to reach a steady state condition.
  15. FrankTiger
    FrankTiger Member
    63
    118
    Madrid, Spain
    Hi spiderman [​IMG]
    There is a XGAUGE that tells the fuel cut-off as I said in this post to Bob.
    In Torque terminology is 7E0 2137 O (if O<16 then fuel is on; if O>16 then fuel is off)
    In XGAUGE could be [I'm not an expert in XGAUGES coding!]
    TXD 07E02137
    RXF 010702E80322
    RXD 3008 (or 3601, 3201 for the exact bit but I am not sure)
    MTH 000100010000
    I discussed it with Adrian Black a year ago but finally it did not go to the spreadsheet.
    Big hugs from Frank
  16. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Hello Frank,
    I do remember that discussion. I didn't think about fuel cut-off and gliding until I ran this new gauge, then I realized the shudder was ignition (got steadier more noticeable over time). Your gauge would have made that obvious too.
    Thanks for the info.
  17. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    We know SG-II tells us actual speed.
    But, we don't know how accurate the SG-II iMPG number is. (I don't believe the SG-II iMPG display. :) )
    My steady state log driving 61.8 MPG @ 63.4 MPH (1.03 gph average) shows between 1.00 gph and 1.09 gph.
    Yes, the display number is not stable, but the number is reasonably accurate.
    It is important to see steady numbers that we drive flat road, steady speed (using CC is preferable) and see accurate MPG numbers.
    My MPG reference is Prius MPG number.
    I set CC speed and reset one of trip displays when Prius reaches at a target speed, then drive 10 km or so a long distance on a flat road.
    Ken@Japan
  18. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    My JP Prius response from "7E0 2137" contains only 13 bytes, so the Torque parameter is A to M, there is no "O" response.
    How many response bytes have you seen from the "7E0 2137"?
    Ken@Japan
  19. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I will have to try your reference using one of the trip displays for the mpg. I was wondering how you were using the Prius mpg :)
  20. FrankTiger
    FrankTiger Member
    63
    118
    Madrid, Spain
    Hi Ken [​IMG]
    Using a terminal, the conversation with the ELM327 is as follows
    >ATS0
    >ATSH7E0
    >2137
    011
    0:61376666834D
    1:7FA0805C000000
    2:447CB546000000
    On the frame labeled 2, the last pair of non-zero digits (&H46) is what I believed is called O in Torque terminolgy [but I do not use Torque, so I may be wrong]
    In the case displayed, the decimal value of &H46 is 70. It is over 16, so injection is cut-off. In fact, at the moment of this reading, the car is in a down-slope of 4% at 80Km/h (50mph) and engine is at 1000RPM. MAF value is 3.54 and "Bank1, Sensor 2: Oxygen sensor voltage" gives us a clue that the injection is off because its value is zero.
    Decimal values I have recorded for this pair [O? in Torque] are:
    0 [standard value for injection ON with RPM<>0]
    4 [initial value with RPM=0 and "low power" injection just before cut-off]
    68 [injection OFF with ICE RPM=0]
    70 [injection OFF with ICE RPM<>0].
    The first pair of frame labeled 2 [L? in Torque], &H44=68 tells the number of 10min periods the system has been off before the actual trip.
    Big hugs from Frank
