scanguage (ver 3.xx) new code & corections for gen II prius
Discussion in 'Gen 2 Prius Technical Discussion' started by epoch_time, May 13, 2013.
  1. epoch_time
    epoch_time Active Member
    240
    113
    las vegas
    07e221c4
    0561 06c4 0000
    4808
    0009 0005 ff85 NAM BCV ( ff85 based on -50c offset adjust for additional accuracy )
    boost converter
    I'm editing this 5-19-13 this gauge seems more like brake pedal pressure than boost converter. It's definately
    not temperature related..Below is my orginal post. Any ideas ?
    I'm only 90% sure that this is boost converter/transistor temperature (farenheit). Boost converter mostly/only used during regenitive braking but this guage may be usefull for inverter/converter/coolant/system temperature when not in regenitive braking (when no other form of inverter/converter temp is available).
    Give me feedback.
    Engine Coolant Temp
    0525
    0105 422d 0000 incorrect version uses 422c which interfers with built in scanguage rpm display.
    1808 if decimal point location is off use 0105 022d 0000 in previous line above.
    0384 000A 0C80 Wth xx.xx °F (use this line for farenheit) Guage seems redundant to scanguage function Wth
    000A 0002 0000 wtc (USE This line for celcius)
    Current Discharge Limit
    03C3
    0103 02CB 0000 internet version (82cb) places decimal point incorectly at 10.5 display should be 105 amps
    1008
    0001 0001 0000 cdl 0-105 Amps
    Current Charge Limit
    03C3
    0103 02CB 0000 internet version (82cb) decimal poinn incorect at 12.5 display should be 125 amp
    1808 starts limit at batt temp 102 degrees. usefull for high resolution batt temp monitoring.
    0001 0001 0000 ccl 0-125 Amps
    Engine Temp (not coolant) 0031 01 00 82 39 00 00 1008 005A 0005 0140 etf °F temp of engine c to f conversion looks funky
    Engine Temp (not coolant) 0031 01 00 82 39 00 00 1008 0009 0005 0020 etf °F temp of engine (this works better 11-16-11)
